Nice improvement! A couple things to consider - doing the bottom first is generally preferred as you'll have a much less obvious seam edge when done. Also, you might be able to get those remaining wrinkles to disappear with a hot iron - you'll be surprised what heat can do! I've been using a small trim iron a LOT on my big Cessna project and love it as I can get really precise applications of heat. Last, depending on how strong the surface is (and how brave you want to get) you may be able to pull the covering even further over the edge. When I do the bottom covering I try and get about 3/4 of the way up and around the edge. Then, when the top is done I try and get that far again towards the bottom sheet which gives me good overlap between top and bottom. But if you're doing two different colors that changes things, and then I'd normally only take the top sheet to the center of the surface.
