bogdanalex
Hello everybody!
I've finally built my first plane from scratch and given the fact that I've got no experience at all in RC, something is not right.This thing doesn't fly ... either it's too heavy or I didn't supply it with enough power, so I thought maybe you could help me figure out the problem.
My plane weight WITHOUT POWERPOD is 395grams ( i've seen somewhere that the weight should be 408g without battery...it's really without battery or without powerpod? ) ....that could throw me 163grams off which is enormous.
my Cub total weigth is 685g with battery and ready to fly....or crash more likely.
I try to use RC TIMER HT2212-1000kv with 07x05 prop and a 2200mah battery with only 8C .
can this prop be too small? It has a good pitch though...
could the motor pull more than 8c and not give enough power?
If anyone successfully built the Cub maybe you could help me with some info....what's your plane weight and what power setup did you used.
