What's new
  • Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
AP Eazy Ducted Fan (50mm EDF Trainer)
STATUS: The maiden flight was successfully completed and the BETA-plan is published!
The AP Eazy Ducted Fan is a EDF Trainer that works with every 50mm EDF unit.
Once in the air, it is a breeze to fly, it is responsive but without any vices and the landings are easy.
Look for yourself:
SPECS:
WINGSPAN: 1000 mm | 39.37 in
ALL UP WEIGHT: 400 g | 14.11 oz (with 3s 1000 mAh)
CHANNELS: 4 (THR | AIL | ELV | RUD)
EDF: HK 50mm Alloy EDF 4800kv 3s (minimum)
DOWNLOAD:
FREE DIY BETA-PLAN
PICTURES:
Grifflyer
WWII fanatic
#6
Awesome work Airc, I love how it takes off from the ground like the grunjet. Quick question how EAZY (sorry):p would it be to make the prop and edf pod interchangeable so that I could have one airframe that could fly off an edf and a prop?
#7
Thank you, but without your Grunjet I wouldn't have thought of it! So thank you very much for your inspiration! ;)
By the way, you can read my mind! I started with this thought, but then I thought, who uses such a thing?
Here are the parts for the EDF assembly, which can replace the Power Pod nacelle:
The problem is of course the detachable fixing of both variants. Two BBQ-Skewers and FoamBoard will not withstand the loads in the long run. Maybe with a plastic reinforcement?!?
You could also slide the two drive units on with the wooden hooks, which I used to fix the top cover of the Rascal Racer, if you then hold it in position with a BBQ stick, it should work.
However, such a solution is nothing for rookies to our hobby. That's why I've published two separate plans.
Grifflyer
WWII fanatic
#8
Okay, cool I think I'll try something after I finish my D.520:D
#10
would something like this work... essentially strengthening the skewer hole with some gift cards... note I found I had to scratch up the back of the card before gluing it...
