Thanks Guys!
So the maiden did not go well. The plane developed a glitch so that at full power or changing power to the EDF, the elevator servo went crazy, deflecting partially or fully up. So full power at launch, plane tried to fly straight up. Take the power off, slight up jerk then settled into flight, power up again, plane pointed straight into the air. It felt like a plane that was going from properly balanced to massively tail heavy every couple of seconds. Managed to glide her in for landing with no damage and that is when I discovered the weird elevator behavior. Switch the elevator to one of the aileron channels and it did the same thing. I thought (and still think) that its interference on the signal line caused by the EDF motor wires. Did a little hacking and routed the servo wire outside the plane to the hatch. On the ground this seemed to solve the issue. However, in the air for the second flight, the problem returned with a vengeance. Managed to get her down again with little or no damage and decided not to throw her up again until I had some time to sort out this servo problem.
Oh well, win some lose some.
@Therry - I hope your maiden went better?
DamoRC
