• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
Battery can I
#2
have a new hobbyzone mini apprentice, came with 3s 11.1 volt 1300 mAh 20c, can I replace that battery with a 3s 11.1 volt 2200 mAh 25c battery?
How much space do you have in your plane for a battery? The 2200 will be quite a bit larger. Also, you will get the same thrust, but your flying weight will go up, so it may struggle, you will probably be giving it a lot more throttle to get similar flying characteristics, and so you probably won't see a big improvement in flying time.
