All good points and suggestions fellas. The imperfections I speak of are weave related. Some times a pinhole is just not filled and I just say it's not worth it to go another round for ONE pinhole. There area few of those that I'm pretty sure will go unnoticed after the paint goes on.
Moving along... More big progress.
Panel lines are created by laying down vinyl chart-pak tape. Do not, I repeat, DO NOT use a no-name brand of this stuff. Go out of your way to find this brand. The off-brand stuff delaminates when you remove it and it is a HUGE pain to fully remove. YOU HAVE BEEN WARNED.
Basic lines added to the small parts and cowl.
Wing top
Wing bottom
Fuselage/empennage.
I'll say here that I used about a roll and a half of the tape. I need to order more now but it's less than you may think to do all of these lines. So, next is more or less weather dependent. And guess what they are calling for on Saturday? Snow. And a record low on Sunday. So yeah... I need to shoot three light coats of primer over all of these lines. Then go back to wet sanding and get the lines sanded back to where I can see the tape again. After that I just peel up the tape and little grooves are left for me to add rivets to.
