Building indeed! First... the vent is about 2cm high and I'm pretty sure I'll be able to get something that will work. The problem really lies in making the whistle deep enough in tone, which requires more volume. This is basic
Helmholtz resonance theory. There are SOOOOO many whistles on thingiverse that I am sure I can find something that I can scale up and insert into the wing.
To kick off this evaluation, here is a reference shot of the very dull and otherwise non-scale oil cooler vents. Vacuum formed plastic and probably fine for a sport-scale model... but that is not what we are after.
First print for this project. The inner vanes direct air inward toward the fuselage so placing a whistle in front of this air flow would absolutely work.
After digging through both halves of the box I was able to separate out the wood that is designated "to be built" and the rest, which is from the assembly of the tail planes and wing. In most kits, and this one is no exception, keep your scrap pieces because you need them for little things here and there. I located the pieces that were "built" and they were more or less incompletely built at this point. There were a couple of errors that I noticed as I placed them over the plans. The elevator balance tab was missing on one elevator and some balsa pieces were missing. Scrap was missing to make up thickness for the U-joiner for the elevators and the tips were not shaped either. The leading edge of the H-stab still needs to be shaped but the corners were beveled. The elevators' ribs still need to be properly shaped as well. Lots of shaping overall needs to be done on these parts.
The V-stab and rudder were in better shape. All the formers were in place and overall shaping needs to be done.
I plan to lighten these control surfaces with holes. I want to cover them with Solartex and its a fairly heavy covering on the tail end. What also is needed is some additional shaping of the framework to a more scale manner. I'll get into this more later but I want it to show through the covering. There are so many walkaround photo references out there because this is such a popular subject. For now,
here is a reference.
