On another note, I've never really covered how I use the reference drawings to apply the rivets.
So basically, I isolate a geometric section and subdivide it per the lines on the drawing. I measure the area on the model and draw out reference lines with a pencil. On curved surfaces I use my smaller cutting mat or cardstock as a straight edge that is flexible. From the drawings, I note where the rivets go. This could be just along the line or on both sides of the line. Some panel lines get rivets along only one side due to panel overlap. It takes time going from the drawing to the model and in this situation, the full-sized drawing is not really needed.
The full-sized drawing comes into play when you need size references for the access panels that I cut from vinyl. It makes things quick and easy. Since they go down before rivets (to prevent bubbling underneath) you also have to measure for placement.
