Building up my Bloody Baron I found in the accessory bag these two foam board wedges. The dimensions seen are inches. My SBK is of the water resistant board, so must be universal between the two. No reference to them in any video, or thread I've found. Admittedly, I only read about 60% of this one.
Any guesses?
Thanks
Marshal
I did ask josh to include a throw setup gauge in the SBK's, but that's not what you have pictured there. I can tell you that they are not part of the airframe.
Are those the triangle squares that they put in to help true up glue joints?
Sponz,
One of the things I've never liked about swappables is the open end of the wing. Just makes them look unfinished.
Did you bevel the ends from top to bottom and then cover them?
Sponz,
One of the things I've never liked about swappables is the open end of the wing. Juse males them look unfinished. It looks like you've addressed that on the Bloody Baron. Did you bevel the ends from top to bottom and then cover them? Could you elaborate on that a little. I really love that design and it will be my next build.
Finally got out to madien the baron this weekend. Ran 4 batteries through it. Flew great. I used a 3s 2200 with a suppo 2217/7 1250kv with an apc 9x4.7 sf. It was a bit slow so i think i may try a 8x6 e. Last landing broke the 9x4.7 so i need to change anyways.
I'm going to ffest. Looking forward to meeing Dan and all the other folks. This plane is going along.
Maidened the plane today, it flew great, but somewhat quicker and twitchier than I expected, so the first minute or so I don't think I breathed out or blinked! Despite setting the throws quite small and 30% expo.
It needs a bit of trim here and there, but my Turnigy TGY-I6S isn't really any good for inflight trim, need to buy a better TX soon.
I have a question.
I used a NTM prop Drive 28-26A 1200kv motor with a Aerostar 8 x 6 prop. I also have some TGS 9 x 4.7E props, does anyone know what difference it would make. I have been using a 3 cell 2200 battery. Any comments/help appreciated.
Basically speaking, going up in diameter or up in pitch while keeping all other things equal will give you more thrust, and more amperage draw from your esc/battery. Too much draw and you'll let me magic smoke out of the esc, which is bad.
There is a pretty good quide to propeller considerations oriented towards electric motors at http://www.rc-airplane-world.com/propeller-size.html
