The only ones in the right size/weight range are the mighty mini twins, i.e. the mini cruiser and the mini guinea; They are spec'd with similarly sized 22-2300kV motors running tiny 5x3 props though. Not too surprising, as the FT guys lately are probably more likely to have the 2300's lying around from their different multicopter projects than the 1300's more common in indoor winged aircraft and such.
I think your 1300kV's might be usable, but probably with different props. The 8x3.8 ones typically used for your motors will not clear the fuse on any of them. Could look like a 7x5 will just barely fit on a mini guinea if the motors will handle them?(not completely unlikely) Note: we're talking something like just 1/6-1/8" tip clearance or so if my somewhat coarse calculations are right, so better double check it yourself. Ought to give similar airspeed and a fair bit more "oomph" than the 5x3 2300kV setup.
On the mini cruiser it looks like there's not really room for so terribly much more than the spec'ed 5" props. If you can find something like a 5x5 prop (I think i saw some 2-bladed 5.5x5 on HK?? Or maybe a 3-bladed?) somewhere, that theoretically might work with your 1300kV's, though I can't guarantee it......
