• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
F-22 Raptor Scratch Build
fliteadmin
Administrator
Admin
In this episode of Flite Test, Josh bixler walks us step by step on building your own F-22 Raptor! This plane is very simple to build, very easy to fly, and also has great trainer tendencies. Watch to see more.
Plans: http://www.rcgroups.com/forums/showthread.php?t=740049&highlight=profil+f22
Parts we used:
Turnigy TG9e Servo
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9549
Hextronik 24gram 1300Kv Motor
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2069
HobbyKing Red Brick 24A ESC
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18003
Turnigy 500mah 3S
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9275
StinkySQL
#3
Just got done crashing mine. As my first push motor I think I got the motor inclination wrong. Just wants to nose over. Next weekend we'll try try again.
Sure was fun to build though.
#7
F22
I personally love F22 Raptors. I just picked up everything from Hobbyking. I'm wondering how the electronics go together. Can someone post a picture/video of how their electronics hook up? I picked up an OrangeRX (6ch) for the rx.
#9
foam boards
hello
I'm in the process of building a raptOR , iv ordered all the stuff from hk . and waiting on the delivery .
here in south Africa . i have managed to find iso board but it is only available in 15mm plus . so i now use project foam board from the stationary shop . i am paying about 40 rand a sheet (5 dollars ). i takes about two sheets to make a raptor IMAG0187.jpg IMAG0188.jpg
#10
I'm such a noob to scratchbuilding and airplanes XD. Here's a dumb question for y'all: What type of foam board works well, and where can i get it?
Foam board mainly varies in thickness, I use 6mm but you can get 5mm 3mm and some thicker stuff two. Where you get it depends on what country you live but the last lot I bought was off ebay, mainly because it's quite expensive here in Australia.
colorex
Rotor Riot!
Of course! This is bigger stuff, but it works just the same. Battery into ESC, Motor to ESC, ESC signal to Rx, Servos to Rx. Mind you I'm using an old Rx which has a super long antenna (black). Don't cut or extend the antenna of your receiver.
#12
Thanks for the picture! Does it matter which servo goes into which aileron/elev slot? Looks like i need a programmable dx6i for elevon control :p. Also, any suggested chargers for the 3S 500 maH?
Here is a Tip for when Building the F22 Raptor on the Prop Cut-out the original design tends to be cause a fair amount of noise,
But if you cut a V shape out towards the rear it cuts down the noise factor slightly
See Attached Diagram diagonal cut-out marked in RED
jetpackninja
More combat please...
Not necessarily a dx6i, but you will need a radio that does elevon/delta mixing.
The dx5e and quite a few lower end radios allow for elevon mixing.
If you are going to be sticking around with the hobby I would definitely suggest going with the dx6i or some other programmable radio.
Plug one servo into the elev, one into the alile. If you are unable to get everything going the right way by trying different combinations of the reverse functions of the servos, then switch the servo leads.
My favorite battery charger = http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7028
colorex
Rotor Riot!
Nope, you don't need a DX6i. You can suffice with a DX5e, but of course a DX6i would be much better and would be useful for longer.
A known issue with DX5e's and DX6i's is that they limit throw on the control surfaces to 50% to make an "exact" mix. This issue can be solved on the DX6i by setting up mixing from Elevator to Elevator, and Aileron to Aileron. On the DX5e it can be "solved" by mechanically increasing throw.
#18
I was wondering about that charger, looked nice and inexpensive. What power supply are you using for it?
jetpackninja
I've used an old IBM laptop adapter, a converted PC power supply and often run it from a 12v car battery at the field.
Currently I'm powering it from a converted server power supply.
It's not picky, give it somewhere between 12 and 17 volts and it's happy.
