• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
FrSky DJT module wont fit in 9x!
lobstermash
Propaganda machine
Sounds like it's blocked by either the pins or the bit of plastic at the base of the pins... I've heard of some people having fit issues, but it's been fixable by slightly enlarging the square bit around where the pins go into the module. Can you post a pic of you tx without the module, and the back of the module?
lobstermash
Propaganda machine
The idea of the plastic is to isolate the connections and make a snug fit with the module... Are you able to wiggle the module side to side as you push it in?
It does look like your plastic bits stick out a little further than mine, by maybe 1mm or so, but it's hard to tell from just the photo.
