I have a few sugestions for you guys building this plane.
1: Instead of scoring and bending on the laser lines. remove the paper from the inside of the wing. This will let the foam bend in a nice arc, creating a much better flowing wing and much nicer looking wing as well.
2: Plan out your color scheme before your final asembly. It helps a lot to plan things out before you have to try and paint/color around other control surfaces.
3: Tape your leading and trailing edges of your wing before you insert it into the fuselage. This will help slide the wing in a little easier, and also help keep the paper from getting messed up. The paper has a weak bond to the foam and can easily peel away, especially if you live in an area with a lot of humidity in the air.
Incase anyone is wondering, the 33 on the tail is because this is my 33rd build
