Thank you, Kris!
Jim, yeah I was honored they took the time to even mention it, I was not expecting that at all! Balsa will most certainly work for you there. I replaced the foam wings with 1/32 balsa on the UM P-51 I converted to brushless as the foam wings wouldve never handled the loads. The sheet of 1/32 I had was pretty stiff so it worked, but If youve got 1/32 thats somewhat floppy, a layer of tape along the leading and trailing edges does a pretty good job of stiffening it up, add a bit of carbon fiber rod if you've got it to give it more strength if needed.
1/32" is also flexible enough that it should conform to the original airfoil shape molded into the fuselage where the wing meets it...the airfoil will flatten out further down the wing, but that shouldnt be a problem. You can make a balsa rib from the shape of the airfoil on the fuselage to help keep the airfoil shape if it needs it. 1/16th will work too and will give you some more material to sand in a nice leading and trailing edge.
Heres a pic of the balsa wings meeting the fuselage on the now smashed P-51. The 1/32 was about the same thickness as the foam wing, so it fit very well and held the airfoil contour nicely, I just glued it directly to the top of the airfoil on the fuselage. Let me know if youve got any other questions
Loghin85, you work fast, and it looks great! Cant quite tell from the picture, did you add the downthrust to the motors? It looks like your motor pods are a bit closer in than mine, if its turning too wide, just move them out a bit (you probably already knew that lol). You'll love flying it, try to get some video when you do, would love to see it! And welcome to the forums, glad to see another micro builder.
Nick
