I am in the process of completing the FT Mustang build, but I am running into rudder slop with link rod no matter how much I adjust the rudder and linkage stopper. Anyone have any suggestions? I do not see any interference with rudder. However, I did make my cut angle on rudder on the wrong side and sealed with hot glue as instructed. I do not see any extra glue in the way to cause the 'bowing' affect the linkage is doing. Thanks for any help. I did notice that I printed the PDF plans from the web and not PDF doc, so I ended up with a 43" wingspan and slightly larger fuselage...a happy accident as it is close to 1100mm now.
I am using an EMAXX XA2212 / 1400kv motor (states equivalent to park 400 size motor), SimonK 30 AMP ESC with BEC and 11.1v 3s 2200mAh lipo ( I have larger ones I can use too as in 11.1v 3s 3000mAh), EVO 9 x 6 prop . I hope this setup works. I do have more new motor(s) I can use - A2212/5T 2700kv, but thought those would be better in a smaller craft, such as a 250 size quad.
