Daniel Kezar
Ultimate Cheap Skate
Does the soaking reduce the smoke and burn marks?
i believe so.
Ok, time for some updates, but first...
In the olden days, microfilm was a thing. I built a few mic models, but that was a long time ago. Last year, however, I acquired a collection of models from a deceased friend's estate. Among those airplanes was a complete set of microfilm covered F1Ds including three fixed pitch props and two more recent variable pitch ones. I estimate these models to be in the range of 30-40 years old based on their design. That's rather shocking to still have good film on most of them. It's possible that these were Joe Bilgri's airplanes, and if so, they are extremely valuable to model aviation since he was the very first F1D world champion, winning the inaugural event in 1960. The box is definitely big enough to accommodate 90 cm models and has stickers going back to the '72 world championship (I've probably missed a few...). Ok, enough blabbering, check out the photos!
Beautiful
This one's much newer: this one's a 55 cm model, so dates to 1999 or later (but the rest of said airplane does not--it's an older modified model).
Absolutely beautiful
Ok, enough eye candy. Down to business. Ground Loop modeled up a prop block for me. It accommodates up to a 26" diameter and is set to 30" helical pitch. I paid him something that will hopefully compensate for some of his work. Seriously, he's the go to man for crazy projects.
This thing is a monster.
What do you need these for? Well, here's a video:
Well, until next time...I don't think I'll be able to work on this for the rest of the week. Southeast Model Show preparations are keeping us super busy. If you're in the southeast, please consider coming and checking out the activities. We'd love to fly with you!
http://www.gamarc.com/SMS2017.html
Nice find! How fortunate that they should fall into caring hands. I love it when a plan comes together.
In grade school I read a novel where the protagonist was a young free flighter. I remember that he made his microfilm in the bathtub and used bent coathangers like bubble wands to capture the film.
What novel was that, SlingShot? Sounds like an interesting read.
I'm sure FAI-F1D will weigh in for accuracy, but in the meantime this should get you started.i
so those big pieces of balsa are a template for the covering film?
Not to steal FAI-F1D's thunder . . . but those are templates for making the skeletons for the surfaces. The outer surface edge (balsa/carbon/boron/whatever) is run around the edge, glued into a loop and the ribs are glued on at the notches. pop them free of the templates when dry and you've got the bones of your new craft.
The film is attached to a square frame (like the microfilm, just not as fragile), then the bones are dusted *LIGHTLY* with spray adhesive and pressed into the tensioned film. Trim the excess film away (soldering iron) and the completed surface (wing/stab/blade) is ready to go.
I've never done anything this elaborate (few have) but I've used quite a few of these steps before . . . with the first at FAI-F1D's guidance. He's going for an unusual crazy strong/light/large balance here, but the steps he's showing off are surprisingly simple in practice . . . assuming you are merely going for "it flies great", instead of "looks like a new record". It's that last few percent of performance that makes it complicated and burns the brains out
