• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
Hobbyking Buddy codes - Share your's here!
colorex
Rotor Riot!
Nice of you to create this post, unfortunately, my purchase was all buddy codes so nothing to share from me... If I get something on Buddy Code later on, I'll share it here.
FPVking
#5
FMA Co-Pilot 2-Channel Flight Stabilization System CPD4
Cheap and good semi-autopilot. Let go the sticks and plane/copter recovers to level flight in seconds. Good item and saves a plane or two for sure.
Trying out new tricks, smoother camera flight, ideal for beginners, also helps when testing range or with fail-safe activating keeps the bird in level flight or make level turn in desired direction. Lots of usages!
Buddy value
Standard value
Valid: 11.12.11
ollis89
#6
Here are some buddycodes from my christmasgiftshopping! :)
Picked up a Tuff Trainer for my little brother to start out with, and figured I needed to treat myself with a Tek Sumo for being so nice to him! :applause:
http://www.hobbyking.com/buddy.asp?code=C9DA14C8-195F-45E1-B634-9830B64672E8
Turnigy L2210A-1650 Brushless Motor (180w)
http://www.hobbyking.com/buddy.asp?code=D7CDFF55-E9A5-494D-8362-52F9E92DFEE1
Turnigy TY-P1 25Amp HEXFET® Brushless Speed
http://www.hobbyking.com/buddy.asp?code=53A8ACE6-2501-4A3D-A8DC-556C1A835267
Turnigy Tek Sumo
And here for some LED strips (time to build a nightflier since it gets dark here in Norway around 4pm) :)
http://www.hobbyking.com/buddy.asp?code=8226E4D7-25F0-4FD7-92D4-48780B3EA4E5 Blue
http://www.hobbyking.com/buddy.asp?code=46E6FB1D-0CB6-4CA3-807E-73E0800B1A00 White
http://www.hobbyking.com/buddy.asp?code=52411497-CD56-4F4D-A4CD-634C6871BBB7 Red
http://www.hobbyking.com/buddy.asp?code=F20393EE-455E-4EAC-94DF-2885A468361D Green
nealcam
#8
MX2 Blue 3D 1400mm EPO (PNF) save 10$
http://www.hobbyking.com/buddy.asp?c...2-A4A531A9C206
Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V2 save 4$
http://www.hobbyking.com/buddy.asp?c...9-5435A7DB422B
Quanum 2.4Ghz Telemetry System Temp/Amp add-on save $5
http://www.hobbyking.com/buddy.asp?c...F-79931E658260
Turnigy Heat Shrink Tube 14mm BLACK (1mtr) save $0.50 per mtr
http://www.hobbyking.com/buddy.asp?c...1-F3D200246A7C
expires in a week, i didnt know about this untill today. pretty sweet
make sure your signed into your hobbyking account for these to work
