Hi,
I am writing here because I am out of ideas on how to solve this issue. I built my first quad with the following hardware:
Chameleon 5 + mini pdb v3
KISS FC V1, RC34
KISS ESC 32a racing, 1.20x voice stable
Emax RS2306 white edition
When I went for my first flight, I managed to lift up and do a bit of hovering, and when starting to put a bit more throttle it did flips of death and crashed. This behaviour is systematic, it happens everytime (check around 0min50s):
As you can see it flies perfectly well, so props are not inversed, motors spin in the correct direction, FC is oriented correctly. After seing this, I added anti vibration pad under the motors and put a capacity of 1000uFahrad on the battery line, as I thought either vibrations or spikes of current would trigger this. NO LUCK!
To go one step further, I flashed the KISS FC with betaflight, and not the KISS firmare. Turns out the hover lasted longer before my quad, nevertheless, ended up in uncontrollable flips of death.
At this point I ordered a new FC, installed it and went to fly today. You guessed it right, still no luck... The very same behaviour happens over and over. I have removed the props, plugged into the KISS GUI, and when I just put it on my hand and arm, the motors spin correctly. As soon as I go closer to mid throttle, all the motors just go crazy. Here is the video showing the data of the gyro, and the rpm on the motors.
When doing this test, I had the same behaviour as shown here: https://www.youtube.com/watch?v=7H-xKuFlxOQ When I use the KISS GUI to test the motors, one by one, they all work perfectly. Even if I try to test all 4 at the same time, perfect response to the throttle stick.
I have absolutely no idea what causes this, and since this is my first quad, I am starting to think about throwing it away and buying something ready out of the box. I spent over 600 bucks to get good hardware and this thing is just getting worse and worse.
I looked all around the web and found nothing. Please help, I'm going crasy here...
KISS FC V1, RC34
