• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
Magnetic building board for balsa models
#6
I have one, made a bunch of the fixtures. Works really well. I was lucky enough to work at a company where I could have them shear a piece of sheet metal and get it painted.
Works for foam models as well, Use a couple of fixtures to hold that 90 deg angle. Hot glue peels of the metal easily.
#8
Years ago I bought an E.J. Lind Magnetic Building Board system. It works reasonably well for holding things true but lacked in clamping force. I still use it for squaring things up though. Looking forward to printing some replacement parts for it soon.
Mike
nhk750
Aviation Enthusiast
#12
So, I ordered a small medium set of fixtures and magnets with my tax return. The mail man came yesterday and forgot to put the parcel box key In my mailbox, so now I am staring out the window at the parcel mail box wondering how to get inside before Monday...arggggggg!!!!!!
nhk750
Aviation Enthusiast
#13
Got the Steel Building Board done!
One of my customers gave me a 20" x 60" section of 18 gauge steel for my building board free! So today I sanded, put 2" gridlines and center lines on it and clear coated it so it wont rust over time. It came out really good and it should be very flat. I also cut out a piece of 1/2" CDX plywood and finished it with Minwax. I will put the plywood on top of my card table underneath the sheet metal to help keep it flat. I could mount the plywood to the steel, but I am afraid it would get too heavy, so with them separated I can move and store them easier. Once I put a finish on the airfield fixtures I will post up a picture of the complete system. This is almost like a build in itself setting up the magnetic build system and it should last me a lifetime, also looking good along the way!
The raw steel.
Sanding it smooth.
Marking the 2" grid lines using a sharpie.
Clear coat finish, using rustoleum gloss clear coat.
Joker 53150
A thousand pints of lite.
I've recently started using the magnetic building surface and absolutely love it. With a 3D printer I'm also able to print some fixtures now to really increase accuracy during the construction.
