FAQ
You don't have the plane/plans I'm looking for, will you make them for me?
If you've wanted to build plane X scaled to Y but aren't sure of the modifications that would be required then add a comment and let me know what you want to build, I'll do my best to make plans for you.
Did you create these plans?
I don't take credit for the following plans, FT and others have created them originally. I've just re-sized, adjusted tabs, A/B folds, and made other small adjustments to make them scale properly.
The electronics you recommend don't match what I've seen others use, what gives?
The suggested electronics are just my opinion, other options will work. I have tested the exact or very similar set up to what I've suggested but if you have questions about a different set up or how a plane will perform with a different set up please post a comment.
Do I need to know anything special before using these plans?
The plans are not perfect and some slight tweaks may be needed. If you have to alter any plans to make them work let me know and I'll adjust accordingly. I have built nearly every one of these planes so far and they all work great!
If I want to use one of the really fast electronic sets up, do I need to modify my build at all?
Make sure you add a CF or aluminum spar with anything more than the Good electronics.
Do I have to use DTFB with these plans?
No, but these plans are designed around the dimensions of DTFB so you might have to make other modifications to get everything to fit right.
You don't seem to offer tiled plans, how do I print full sized plans?
1. Open the PDF you want to print using Adobe Reader X.
2. Click the Print icon.
3. In the Print dialog box, click Poster.
4. Set Tile Scale to 100%.
5. Set Overlap to 0.005in.
6. Click Print.
PLANS
UMX
Coming soon!
50% - 5-600mm
Coming soon!
80% - 800mm
ELECTRONICS
Minimum | Good | Great | 80+ MPH | 100+ MPH |
1000mah 3S Blue Wonder 8x4 APC 400g | 1000mah 3S NTM 28-26 1350kv - 56g 220w 8x6 APC 420g | 1500mah 3S NTM 28-30 1200kv - 67g 350w 9x6 APC 500g | 2000mah 3S NTM 28-36 2200kv - 87g 700w 7x6 APC 580g | 2000mah 4S NTM 35-36 1800kv - 117g 875w 7x6 APC 680g |
800mm PowerPod
Plans 2000mah 4S will fit inside.
FT Flyer - 525mm (Blue Wonder or smaller motor suggested)
Plans
FT Viggen - 480mm
Review - Plans
FT Mustang
Review - Plans
FT Racer
Review - Plans
FT Spitfire
Review - Plans
ultramicrobe Messerschmitt & P51
Review - Plans
Plans
FT Viggen - 480mm
Review - Plans
FT Mustang
Review - Plans
FT Racer
Review - Plans
FT Spitfire
Review - Plans
Review - Plans
120% - 12-1300mm
150% - 14-1600mm
ELECTRONICS
Good | Great |
3000+ mah 3S 117g 350w 910kv 10x4 APC 3000+ mah 4S 65g 300w 800kv or 89g 400w 1000kv 12x6 APC | 4000+ mah 4S 171g 815w 900kv 12x6 APC |
FT Bloody Wonder v2
Plans
Plans
200% - Build tips
FT Spitfire - 2100mm (83in)
Review - Plans - Build video
FT Dusty - 1500mm (60in)
FT Old Fogey - 1850mm (74in)
FT Mini Scout
Plans
Build Threads
nerdnic
nerdnic
Build Threads
EraJomppa
EraJomppa
FT Mini Scout
Plans
