Hey that a great job with updating all the plans! Thank you man. It's awesome
Before I scratch build any RC plane I am trying to 3D visualize the model in SketchUp. Then I can be sure that everything will lineup...
So I open PDF plans in the Inkscape and save it as DXF file which I then import in SketchUp.
Sometimes I found that the cavity for a fold is a lot narrower than 3/16 inch (or 5mm) so I know that I will have hard time with the fold unless I widen it.
With FT 3D and FT Explorer plans it went OK.
But I
found some inconsistency with a Bushwacker plans v1.2. I am curious if this is the same with version v1.0
The top deck of the fuselage is wider then bottom deck, also the rear windshield (part 03) is with the same widht of the top deck.
See the picture:
With the top deck also the cavity for a vertical stab seems to be off off the center axis (one half of top deck is bigger then the other):
The power pod plate (part 04) protruding on the rear part from the fuselage (slided to the front as far as it can go):
So I am not sure if it is all intended (foam can be bent...) but didn't come across such inconsistency with the other two planes I mentioned above.
If top deck should be more wide than tha bottom deck of the fuselage, than power pod plate is not protruding but still the vertical stab center line is off.
