Imanewb
I could use some help on this one. I am running the Suppo 20A ESC and Suppo 2208/14 motor and the motor is cutting out on me. At first I thought it was a bad battery but I connected a low battery alarm and noticed something odd. I will post a video to help describe the issue better.
Symptoms:
On 3s 500ma battery within seconds of take off at just above half throttle the low battery indicator will beep and I have noticed reducing throttle will allow me to coast back to land but if i increase throttle or leav it I will loose power completely.
On 2s 850ma I can safely do just above 3/4 throttle and have been able to go full throttle for maneuvers.
Batteries are less than a 2 week old charged and only charged with a Turnigy Accucel-6 with maybe 3 flights on each. I have only balance charged them and storage charged them every time after use.
The setup in video is:
Suppo 20A ESC
Suppo 2208/14 motor
GWS Propeller (EP-8043)
Battery (Turnigy 1000mah 3s)
Thank you in advance for the help, I am really stumped here.
Video of problem. If I continued to run motor past alarm it would have cut off but I didn't want to in case that's bad for the battery.
Symptoms:
Suppo 20A ESC
Suppo 2208/14 motor
