Fluburtur
Cardboard Boy
After the disappointment that was the crash of my canadair into a tree I decided to built yet another plane (it's been like 3 months since I last built a plane, can you even imagine)
I decided to build a bush plane for slow flying and acrobatic flight, this way I can fly at the park where trees are not in the middle of a goddamn river.
I learned a few things from the canadair, the most important being that the eppler 205 got tons of lift! I could almost hover it in no wind and it likes flying inverted too so im going for a low wing loading and nice wings for good slow speed flying. I am also aiming for a high TWR for some prop hanging and knife edges.
Since I now have a 3d printer I decided to make the tail and landing gears with it!
I tried to make the tail very light, it is a simple 3d printed frame covered with clear tape. I think it is about 45g, I wanted to make it light as possible in order to avoid nose weight.
The gear isn't done yet but I used a fairly clever design, it uses 6mm BBs in a sort of ball bearing. The inside of the bearing is made in two parts that clamp down together and the outside is one simple part. This way it is the balls that hold the wheel and deal with all the loads, I need to tune my printer a it but it works fine already. I will probably make a video about that because it is a bit hard to explain.
Today I cut the body, I have enough foam to make maybe 3 of them but I want to build a flying wing too.
I don't have the electronics yet but I will probably make the wings soon and I need to finalize the landing gears design, as always I will keep you informed!
