Maiden didn't go so well.... I had to add weight to the nose and it even though it was finally nose heavy, i don't think it was enough. throttle up, tossed it in the air and it wanted to climb. I backed throttle off, tried to nose down a bit and then she started turning to the right with no input from me. I tried to turn left to avoid a tree and nothing, no response except still slightly going to the right. At this point i had to get it on the ground because there were other objects it would eventually hit. my mistake was cutting the throttle completely thinking i could glide it using the elevon, problem was that i didn't have the speed need and when i cut the throttle it dropped nose first onto the pavement. Only damage was the prop broke, but i was surprised because it took a pretty good nose first shot into the ground. Turns out the screw on the linkage stopper for the rudder was loose and the servo rod was not moving much causing no response when trying to turn. I fixed it and will see if i can get another maiden in today, weather permitting.
