PsyBorg
Wake up! Time to fly!
Right now I am highly pissed off so I am gonna vent a bit. You can skip down a few paragraphs if you want in on the real part of the conversation.
Why the !@#$!% do programmers these days INSIST on forcing updates on everyone. EVERY time I have every got tangled in a forced update it has totally @!#$!@#$ up how things worked perfectly previously on what ever it was that got updated. Right now I can fully understand why someone just walks into a random business and attacks the first people they see. It has nothing to do with the people its just the !@#$up system that no one has a recourse from problems that are caused by the STUPID people running things these days. What ever happened to common F'ing sense. Have we bred that out of our genetics at this point? Its like everything someone needs or wants to do digitally has become the most intrusive degrading moronic cluster !@#%%^ humanly possible.
How hard is it for one of these idiots to package what is needed for their products. They already have it all. They already proved it works. Yet these morons insist on taking the lazy way out (Which btw for all you lazy people 99% of the time ends up as more work anyways.) can't put it all in one package.. NOOOOO you have to go to 5 other websites they link you to after hours or days researching why your stuff no longer works. THEN you have to submit to a full background check, a lineage run down, and finally a full on digital cavity search just to get a simple driver that should have been put in the program in the first !#$!@#ing place.
AAAAAAAAAAAARRRRRGGGGGGGGGGGGGGGGGG!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Does anyone else want to implement an annual beat the crap out of a dev national holiday like I do?
Ohhhmmm mada padma ohhhhmmmm ..... breathe in ... breathe out.
Ok on to the issue at hand. I have been having an issue with one of my motors randomly working or not.. Physically they are fine and work. The esc is good as well. Swapped them both out for brand new replacements still no fix. That kind of leaves a software issue at this point. Normal thing is to reload software and see what happens. So I fire up the working KISS gui and try to reflash the esc's. The Gui shows motors 1,3 and 4 having firmware on it that is supposed to be there. Number two is totally blank. I figure cool. it forgot what it was supposed to do. (this is pre motor and esc swaps btw) I reflash and it goes thru the process fine. No dice still same issue. Reflash again still no fix. So I figure maybe the FC firmware is the issue. Dummy me thinks.. OK if I gotta go thru all this anyways may as well update to the latest and greatest. I flash the newest firmware unplug the controller to reboot it and now I have nothing.
I get no usb connection, I get no blue lights on the FC only the green power light. The lights on the esc's flash and then go out. Bills law strikes yet again....
Soo I figure that I will revert back to what I know works and let other more qualified people work out the issues with the new stuff. Fire up DFuse and reflash to the firmware I was using no problem. Do a reboot and again nothing. Now to top it all off it will no longer connect thru the usb at all. Not the bootloader, not the gui, NOTHING.
I have just spent the last two dam days trying to uninstall drivers and reload them. For that I did the normal uninstall if the software had the uninstall, if not I did the windows uninstall. Cleared out all the remaining files and folders that randomly get left behind when doing this. COLD booted the computer to make sure nothing remained of the drivers. Even ran a registry cleaner to finish clearing left over keys and reg entries and what not. Cold booted again and started the reloading of drivers. After several runs thru that fiasco I STILL can not talk to the FC. I only get this widows message.
This does not look like the normal driver not found as it specifically states device failed. Am I beating my head on the wall here and my FC took a dump or is this still a driver issue?
