I have to smile a bit over the likeness between the inflatoplane and RCGroups Tony65x55's "Tuffy" trainer scratch built. A piece of pipe insulation around the boom, either with a bit of a cut out for the prop or perhaps with some sort of simple motor carrier thingamagic just stabbed into the foam fuse, and the "scale-ish" looks are almost there
. With a little bit of effort put in, you can build one of these overnight.
And yes, the subsonex is quite a nice looking little plane (Although I'd personally more likely go for a Rutan LongEZ, regardless if jet or prop). Shouldn't be mixed up with the
Saab Sonett, though - probably one of the wierder fairly nice looking small "sports cars" out there - especially the early ones with the 3-cyl. 2-stroke motor.
EDIT: Yup.....too much off-topic.......admitted
Revere? I think you "have the ball".....?
