The standard power pod gives a small amount of right thrust and is designed for the use of a CCW propeller and a motor that rotates Counter Clockwise, (CCW), when viewed from the front.
The propeller blades will have a slight curve from the front, (Leading), edge of the blade to the rear, (trailing), edge and this curve should face towards the front or in the direction of flight. If you fit it the other way around the prop will not work as well as it should.
