Results 1 to 7 of 7
    Senior Member Greg2B's Avatar
    Feb 2014
    NY/NJ
    112
    Post First Tricopter Build | BlueSkyRc Micro TriCopter
    I'm starting up another build and I'm going to attempt my first tricopter. Seeing David tri is probably one of the first thing that got me thinking about multi's but the using servo's scared me since I've never even really thought about them until I got into all this.
    Recently I just randomly got a servo from radio shack with the intention of testing it out and seeing if I could get it to work. Of course when I finally did test it I blew it up using the wrong voltage....
    I'm going to be using the parts from my first quad the turnigy microquad so
    • Turnigy T1811-2900kv Brushless
    • Turnigy Plush 6A
    • kk 2.0 flight FC
    I'm currently using a Turnigy Servo 5.5g but I also have two 9 grams as well. My micro tricopter is going to be using the BlueSkyRc Micro frame. I already painted and put the frame together.
ID:	27772Click image for larger version.
ID:	27771Click image for larger version.
    I also went ahead and put the motor mounts on and used a rapstrap to attached the servo for testing.
ID:	27776Click image for larger version.
ID:	27774Click image for larger version.
    Seems like everything works fine. The only issue I've notice so far is the servo arm doesn’t like staying on the servo. I'm think add some glue would solve this issue but I would hate for it to be off a bit and I need to pull it of to readjust and can't. Here is a video of me testing the servo.
    This looks good right? Based on the youtube videos I've found this looks all right.
    Side note I just remembered from an email today that I actually did support the pocket drone kickstarter, which should be coming soonish, since I really wanted a tricopter back then but didn't think I could build one. Sort of wish I didn't spend the money it now...but it should be another neat addition to my fleet.
    Quote: My quad just pulled an Icarus...
    My fleet:
    DroneKraft Mach300 GT - In the Works...maybe
    BlueSkyRc Tricopter - Needs Re-tuning
    BlackOut Mini H Quad
    Hovership Micro H Quad - In the Hangar
    SSHQuad v3 - In need of Repairs
    Turnigy Micro Quad #2 - Dead
    Turnigy Micro Quad #1 - Dead
    Red Eye One
    Blade Nano QX
    Hubsan X4 107D
    Hubsan X4 107C #2 - Broken
    Hubsan X4 107C #1 - Dead/Lost
    Hubsan X4 107L
    Helicopter addict stay-fun's Avatar
    May 2014
    Mountain View, CA
    793
    Since the shaft of your servo and the shaft on which the tilt pivots are not aligned, you have more travel in one direction than the other. The KK2 board will probably be able to fly it, but you may have sluggish yaw control.
    Other than that I think it looks pretty neat!
    "It's better to admit our ignorance, than to believe answers that might be wrong." - Neil deGrasse Tyson
    Feb 2014
    NY/NJ
    112
    I put it all together yesterday and it flies. It actually flies quite well. After tweaking the offset if the tail motor it was quite stable in the air. The yaw on a Tri is pretty crazy, I can see why David and many others like them so much. The frame is also pretty durable too I crashed it into a bush (around 4:00) and it survived without any damage.
    I'm looking forward to seeing what I can do with this frame especially some flips
    I took a few still from the video as well since I thought they looked cool.
Name:	Tricopter Motion Pic1.jpg
ID:	27868Click image for larger version.
Name:	Tricopter Motion Pic2.jpg
ID:	27869Click image for larger version.
Name:	Tricopter Motion Pic3.jpg
    Here are some stills of the my final build. Kind of messy but I can clean it up later. I'm also thing of getting some better esc's.
ID:	27867 Click image for larger version.
ID:	27864 Click image for larger version.
    My fleet:
    Red Eye One
    Blade Nano QX
    Hubsan X4 107D
    Hubsan X4 107L
    Oct 2013
    sweden
    38
    looks good mate, but those bearings on your yam motor sounds horible, u better replace them!
    Posted a thousand or more times C0d3M0nk3y's Avatar
    Jun 2014
    Missouri, USA
    1,716
    Very nice.
    Feb 2014
    NY/NJ
    112
    Thanks C0d3M0nk3y & MelkerSkogstam
    and yeh really should just replace all the motors and probably the esc's while I'm at it...
    My fleet:
    Red Eye One
    Blade Nano QX
    Hubsan X4 107D
    Hubsan X4 107L
    Kite Eating Tree Trimmer cranialrectosis's Avatar
    Colorado Springs
    5,356
    I like that frame. The copter seems to fly pretty well too.
    Nice one, Greg2B.
    Freiheit schöner götterfunken tochter aus elysium!
