Page 19 of 19 FirstFirst ... 9 17 18 19
Results 181 to 185 of 185
  1. #181
    Flite Test Groupie BridgeInspector's Avatar
    Join Date
    Feb 2013
    Location
    Knoxville, TN
    Posts
    1,044
    That is a beauty Rasterize!
    The addiction is real and contagious.
  2. #182
    FT CAD Gremlin SP0NZ's Avatar
    Join Date
    Sep 2013
    Location
    Wisconsin
    Posts
    2,626
    Quote Originally Posted by Rasterize View Post
    11X17 skin set for this:
    Attachment 94392
    Cane be found here.
    Great work on the skin Rasterize! I think I need to update the Scout plans. I have a feeling a lot more people are going to be building this one.
    -Dan Sponholz
    SPONZ - Plans Index
    Designs
    : Bloody Baron | Baby Baron | Baby Brit | Ugly Wonder | Bloody Wonder MkIII
    Coming Soon: Intruder | Bloody Brit
  3. #183
    those look good man! i gotta make some guns for mine!
    laters,
    jason
  4. #184
    Join Date
    Sep 2013
    Location
    Wisconsin
    Posts
    2,626
    The FT Mighty Mini Scout plans have been digitally remastered by yours truly. You can get the updated version 1.1 plans here:
    http://forum.flitetest.com/showthrea...NZ-Plans-Index
    I will check with the admins to get the links in this build thread updated as well.
    Enjoy!
    -Dan Sponholz
    SPONZ - Plans Index
    Designs
  5. #185
    Yenya's Avatar
    Join Date
    Dec 2017
    Location
    Brno, Czech Republic
    Posts
    1
    Question
    Hello, all!
    Let me present my Mini Scout "Hina":
    (click the image for a short flight video)
    My Mini Scout is built from 3mm XPS boards from a local hobby store (pinkish-orange), covered with 80 micron laminating film. I used a styrofoam glue UHU-Por instead of hot glue. I built it with removable wing and detachable landing gear, wheels are 3D printed from PET-G, as well as the motor firewall. I use 10A ESC, 800 mAh 2S battery, 2205-sized 2300KV motor, 6x4E propeller. The weight with battery is about 160 grams.
    I have a question, though: I had to point the motor axle much more downwards than the original build video suggests, otherwise it would porpoise up and then stall on throttle increase. Currently the axle points few degrees more downwards than the front third of the wing. I use the same right thrust angle as the power pod in FT plans (about 4).
    What downwards motor angle do you use, measured from the top flat side of the fuselage?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
