Page 1 of 11 1 2 3 ... LastLast
Results 1 to 10 of 108
Thread: NutBall Scratch Build
    Administrator flitetest's Avatar
    Navarre, OH United States
    317
    In this episode of Flite Test Josh Walks us through the Nutball scratch build. This plane is very cheap to build and flies great. Watch this episode to see more.
    What We Used:
    Hextronic 9 Gram Servo
    HEXTRONIK 24GRAM BRUSHLESS OUTRUNNER 1300KV
    Red Brick 25A ESC
    GWS EP Propeller (RD-8043 203x109mm) (6pcs/set)
    OrangeRx R610 Spektrum DSM2 6Ch 2.4Ghz Receiver Turnigy 500mAh 2S 20C Lipo Pack
    PLANS:
    Nutball Thread
    http://www.rcgroups.com/forums/showthread.php?t=836389
    Nutball Plans on RCGroups.com http://www.rcgroups.com/forums/showt...=836389&page=2
    KFm4 build on a 36" Nutball using 6mm Depron or FFF http://www.rcgroups.com/forums/showthread.php?t=1049935
    Senior Member John Campbell's Avatar
    Memphis, TN
    453
    Nice... I think I am going to try to build one of those.... I already have everything but the foam... Not sure I understood Josh, and correct me if I am wrong. Did he say "Dollar Store Foam" and if I heard correctly, what is "Dollar Store Foam" I have been in a lot of Dollar Stores, and never have seen sheets of foam...
    Great Job Josh... Missed seeing Josh Scott though... Should have had him do the maiden flight
    Senior Member fred0000's Avatar
    Jan 2012
    Vancouver Island, Canada
    217
    great video, I think I might build one to these specs.
    a couple 450's, HK-250GT
    What was the diameter of the main circle on your build? I didn't see any measurements on the drawing.
    2,717
    Yep, its Dollar Store foam. I'm not sure if every dollar store chain carries it. It is also known as Rediboard or foam core.
    Jan 2012
    217
    i've only ever seen the stuff at one of my local dollar stores, i'll be grabbing a sheet or 2 next time i'm there, beats the LHS price by a long shot. (though LHS has a much better selection)
    Full Circle teflyer's Avatar
    Texas
    402
    If you cannot find the foam locally, just buy the bulk if you are planning to do more scratchbuilds. Do you have a Dollar Tree locally? You can order 50 sheets for $50 + shipping with a store pickup. Pretty good deal! oh, and also known as Adam's Foamboard, I believe.
    and HobbyKing Ruler in the video !
    With every bad flight, there is a lesson
    Hmm... I guess I had a lot of lessons
    Hindsight: I post, I edit, I post, I edit, I post, I edit...
    Senior Member Fishbonez's Avatar
    Cheyenne
    567
    Quote Originally Posted by earthsciteach View Post
    Here the "Dollar Store" does not sell it but "Dollar Tree" or "Everything Is A Dollar" sells it
    It will fly or it will go home in a box
    Memphis, TN
    453
    Quote Originally Posted by rickthebrewer View Post
    17", if you download the full size print is printed right in the center. I think that I am going to have the full size printed on one sheet.
    Memphis, TN
    453
    Great info... I will have to go shopping for it. I may recognize it when I see it.
