Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 10 of 180
Thread: F-22 Raptor Scratch Build
    Administrator flitetest's Avatar
    Navarre, OH United States
    319
    In this episode of Flite Test, Josh bixler walks us step by step on building your own F-22 Raptor! This plane is very simple to build, very easy to fly, and also has great trainer tendencies. Watch to see more.
    Plans: http://www.rcgroups.com/forums/showthread.php?t=740049&highlight=profil+f22
    Parts we used:
    Turnigy TG9e Servo
    http://www.hobbyking.com/hobbyking/s...idProduct=9549
    Hextronik 24gram 1300Kv Motor
    http://www.hobbyking.com/hobbyking/s...idProduct=2069
    HobbyKing Red Brick 24A ESC
    http://www.hobbyking.com/hobbyking/s...dProduct=18003
    Turnigy 500mah 3S
    http://www.hobbyking.com/hobbyking/s...idProduct=9275
    It's so easy that I want to try it now! My guess is that a Park450 will need a slightly larger plane
    Just got done crashing mine. As my first push motor I think I got the motor inclination wrong. Just wants to nose over. Next weekend we'll try try again.
    Sure was fun to build though.
    Technical - but not in fluid dynamics ...
    Wink
    Great!!! You can pass a link to the plans of this aircraft?
    Where can I find the link for the plans ?
    Quote Originally Posted by runnerba View Post
    They are posted under the first video:
    http://forum.flitetest.com/showthrea...85-F-22-Raptor
    Member rcmaniac098202's Avatar
    Bay Area, California
    30
    F22
    I personally love F22 Raptors. I just picked up everything from Hobbyking. I'm wondering how the electronics go together. Can someone post a picture/video of how their electronics hook up? I picked up an OrangeRX (6ch) for the rx.
    30
    I'm such a noob to scratchbuilding and airplanes XD. Here's a dumb question for y'all: What type of foam board works well, and where can i get it?
    Post foam boards
    hello
    I'm in the process of building a raptOR , iv ordered all the stuff from hk . and waiting on the delivery .
    here in south Africa . i have managed to find iso board but it is only available in 15mm plus . so i now use project foam board from the stationary shop . i am paying about 40 rand a sheet (5 dollars ). i takes about two sheets to make a raptor Click image for larger version.
ID:	4708Click image for larger version.
    Member Bollie's Avatar
    Perth, Austalia
    71
    Quote Originally Posted by rcmaniac098202 View Post
    Foam board mainly varies in thickness, I use 6mm but you can get 5mm 3mm and some thicker stuff two. Where you get it depends on what country you live but the last lot I bought was off ebay, mainly because it's quite expensive here in Australia.
    Bollie
    I can see my house from here....
