Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Delt Wing - Looking for some advise....
    Senior Member jd7792's Avatar
    Mar 2012
    Coogee West Australia
    122
    Hi guy's,
    Still waiting on hardware and electronics to finish this project, but in the mean time I thought I would seek some advise about my wings profile. As you can see in the two photos below the shape is basicall the same as most wings. It has a wing span of 30" a wing depth of 9.5" and a centre length from nose to motor mount of 11".
    I notice that a lot of people use pink foam to make their KF Air Foil, but I have been limited with the foam that I have available. So I decided to use two extra pieces of depron to built the density up. While I was playing with the first part of the Air Foil I found a 3rd piece of foam that was thinner than the original foil. I cleaned it up and came up with the idea that is in the attached photo's. As it is I have a two step AF Air Foil, but I am not sure how that will work so now I need some advise before I glue everything together.
    So my question is, "Will a two step AF Air Foil work?" If so can anyone tell me how it will effect the overall wing?
    Please let me know what you think...
ID:	4912Click image for larger version.
    jd7792
    Just Remember, I Never Crash,......I Just Park at High Speed!
    Here is the basic sheet on KF characteristics. Most people use Kfm2 or 4 on their flying wings - 2 because it gives it a floaty feel and 4 because it is locked in for speed with good glide. 3 is mostly for gliders as attached because it generates good lift, but you do not need this for a flying wing. You can try it as an experiment? I would stick with what you got at the mo because you can always add more steps later.
    Jim
    Jim
    http://www.youtube.com/user/Rcjim11
    The 'Most Fun Per Buck Club' rules state...............'the amount of fun you have is directly related to how much money you don't spend'.
    Mar 2012
    122
    Thanks Jim,
    I have actually seen something like you posted before, but 1) I couldn't find it and 2) I don't think it had the third foil on it. I really appreciate your help. I am hopeful that someone, somewhere has done something similar and can give me an idea whether to keep going or change it before I make it permanent.
    Thanks again
    JD
    jd7792
    I'm back (I think) colorex's Avatar
    5,236
    Just remember to sand the leading edge round and put tape on it!
    A CareBear is my Co-Pilot earthsciteach's Avatar
    3,136
    Also, consider covering the entire wing with either poster laminate or something like econokote. It adds a tremendous amount of strenth!
    Looks good! The wing sweep looks pretty good for a decent cg.
    More combat please... jetpackninja's Avatar
    Gravity bound to the 3rd planet (Lehi, Utah)
    1,398
    13
    Search for articles and posts from Schraut5 he has built several similar type wings
    I think, therefore I crash
    Full Circle teflyer's Avatar
    Texas
    402
    If I may ask, what percentage of the wing chord did you put the steps?
    When you fly it, I would suggest putting a little reflex just in case.
    With every bad flight, there is a lesson
    Hmm... I guess I had a lot of lessons
    Hindsight: I post, I edit, I post, I edit, I post, I edit...
    3,136
    Reflex is a good idea, but you can cheat by trimming your elevons up.
    1,398
    13
    Quote Originally Posted by earthsciteach View Post
    Up trim on the elevons is reflex
    Some wings (I think this is what you are getting at) cut reflex into the wing profile itself. The effect is the same.
    3,136
    Yep. I find a good ol' Clark Y works just fine with the elevons trimmed up! Now, the one I'm working on at this very moment will have reflex built into the airfoil profile. Just because.
