Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 77
  1. #21
    what about swapable fpv planes???
    My youtube channel
    There is no such thing as a dumb question. Only dumb people dont ask dumb questions, smart people ask dumb questions!
    Bixler FPV
    Annsman virus 2.0
  2. #22
    Senior Member SteveOBHave's Avatar
    Sydney, Australia
    294
    Quote Originally Posted by Bbjen View Post
    Here is mine, got to find a bigger flying field but you know what, this plane is tuff....
    I'm sorry but I had to have a laugh at the lamp post - what are the chances Nice build!
    It looks to me like your delta might be a bit tail heavy, you might find it a little less of a handful if you shift the CG forward a little.
  3. #23
    Mar 2012
    Villebois, Canada
    90
    I'll try that, but for now I need props, this was a 5inch, maby too little, and my prop saver stripped off. As for the fuselage and wing, good as new. this airframe is tuff!
  4. #24
    Jul 2012
    Denmark
    4
    Does anybody know if these dollartree foamboards are available in Europe, or in a shop that ships international? The price here in Denmark is many times that from dollar tree, and the boards are smaller. Would be nice if I could order a case with 50pcs but don't think dollar tree ships to Europe.
  5. #25
    hotwax's Avatar
    Türkheim, Germany
    301
    Foamboard in Europe
    I found foamboard at www.modulor.de at 3,95 € for a 5 x 500 x 650 mm per shiet. I made Fuselage, FT-Flyer, Nutball and Delta-Wing out of 4 boards. Not as cheap as in USA but a lot of fun for the buck.
    FT-Flyer has a span of 30 inches, Nutball 20 inches. Delta-Wing is stock with a bit of fiddeling at the wingtips.
    I think a Funbat would be nice too, because there is no mixer nessesary.
    have fun
    Werner
  6. #26
    Jun 2012
    3
    Awesome plane! I built mine's using 6mm Depron, fuse reinforced with extreme packing tape and wing reinforced with a 3mm CF spar.
    I'm very happy with it.
    You can see a picture:
    And one flight:
    Thanks flitetest for this fun design!
  7. #27
    Jul 2012
    Denmark
    4
    Quote Originally Posted by hotwax View Post
    have fun
    Werner
    I bought foam from epp-versand.de. The price was good and shipping not to expensive. Much cheaper than from local shops.
  8. #28
    Monroe, Louisiana, United States
    17
    I want some plans for the fuse and Delta that I can print out like normal. I cannot print the plans on multiple sheets. All the measurements aren't on the single sheet.
  9. #29
    hotwax's Avatar
    Türkheim, Germany
    301
    Quote Originally Posted by constantmotion View Post
    Seach for posterazor, its freeware. Than you can.
  10. #30
    hotwax's Avatar
    Türkheim, Germany
    301
    Depron from EPP-Versand is fine but I found no qualitys with paper on both sides.
