Results 1 to 10 of 10
Thread: NAZA GPS Help
    Senior Member saundw's Avatar
    Apr 2012
    Maine
    110
    NAZA GPS Help
    I have a flame wheel 450 quad with NAZA controller and GPS. When I turn the quad on in GPS mode, the LED flashes red and green. When I takeoff, it does not hold it's position. The IOC works but it does the GPS does not appear to be working. I live in Maine. Is it that I don't have enough satellite reception?
    Thanks
    -Will
    "That wasn't me it was a radio glitch"
    Springfield Oregon
    272
    Do you wait for the LED to turn solid green? The flashing red and green says it is getting the satellite information. One has to wait for the solid green to fly.
    Apr 2012
    Maine
    110
    Wait a minute while I go hit myself over the head with a brick.
    -Will
    Apr 2012
    Maine
    110
    Hmm. Just tried it. I waited for the green light to flash. It did. I took off and it didn't seem to be working. Than I got a low voltage indication. Could it be that I have to fill out the Mounting page in the assistant software for it to work?
    -Will
    Springfield Oregon
    272
    Describe what makes you think it is not working?
    Apr 2012
    Maine
    110
    When I enter GPS mode and the light is a steady green blinking and I take off, the does not hold it's position. It goes in what looks like a big circle with a radius of about 10 feet. The IOC does not work either.
    -Will
    Springfield Oregon
    272
    It is all in your gain adjustment. Some test you can do is to run in GPS then go to Atti mode and see the difference. In Atti it will drift with the wind, go back to GPS and it will try to stay in one spot. Do you an 8 channel radio? You maybe able to set it to adjust the gains in flight. There are so many variables as each fight vehicle is so different, so the gains are dependent on the unit it is in. Another test is to get it set with GPS and do fast forward, fast reverse passes then stop. Does it try to return to the same height it was before it lost height in fast flight? If so, it is working. Check the Manuel on how to set the gains. What has worked for others with the same QAV 500 frame as mine, is to much for mine. Motors, props, esc's all seem to make a difference. Props seem to make a huge difference, at least that is my understanding. The more flexible the prop, the less precise control. Experience has shown me that the location of the GPS antenna is very important. The closer to the center the better it flies.
    Other thought, did you do the Digital Compass Calibration per instruction Manuel? Might help.
    Here is a thread on another forum, you may find useful information you can apply.
    http://fpvlab.com/forums/showthread....-by-fpvmanuals
    Start close to the end for best information.
    Apr 2012
    Maine
    110
    Got it working! All is good!
    -Will
    Member PunkStar Studios's Avatar
    Maple, ON, Canada
    68
    Quote Originally Posted by saundw View Post
    So what was it?
    Gains?
    Compass calibration?
    Apr 2012
    Maine
    110
    It was a mixture of gains, and being patient for the GPS to lock on fully.
    -Will
