Is there a way I can do the FRsky upgrade on the 9x and also add a patch antenna for long range FPV?
Also, what is the best way to set up GPS, osd, and a RTH function?
thanks guys,
Ben
thanks guys,
Ben
"Trust me, it's suppose to fly that way..."
Yes! The FrSky module just plugs into the back of the 9x. There's also a DIY kit that requires some soldering inside the tx, but if you use this buddycode: http://www.hobbyking.com/buddy.asp?c...6-484B56EB77C8 the module combo is about the same prices as the DIY telemetry stuff. The patch antenna screws into the same spot as the normal antenna and has the same connector. There's also a 1W booster for about $40 on ebay: http://www.ebay.com.au/itm/1W-Wirele...item1e69e3597f, which you screw into the module, then screw the patch antenna on the end.
The cheapest OSD with RTH is the NOVA OSD, which is $120 from BevRC: http://www.bevrc.com/nova-osd-v11wit...-bug_p279.html or about the same from FoxTechFPV (sold out).
There are mixed reviews on the NOVA, but bmsweb uses one and finds it pretty handy.
EDIT: By plug and play, you have to cut the antenna of the FlySky module off, and I'd recommend pulling the old antenna off the top.
Allow me to plug a great guy: Buy your FrSky module at www.parkeflyer.com. He was kind enough to upgrade my 9x to er9x and add a couple of other upgrades, even though he had discontinued that service. And his prices are competitive. And his service is excellent! Beat that, HK!
does the signal booster run off the TX battery? or is that separate?
also, do I need to do anything to the receiver if I go with this?
edit, one more thing: if I go with fatsharks from hobbyking, how do I set that up with foxtech's 5.8 system.
Sorry for all the questions, I am trying to make sure I do it right.
It runs off a separate power supply (5-6V). I'd get a UBEC and run it off a 2s or 3s Lipo.
The receiver just does its thing and receives the signal. It's best to make sure the 2 antennas are 90 degrees apart to get the best performance, but that goes for boosted signal or no. The booster is just making the tx output 1W instead of the stock 60mW.
is there anything I need to add for the fatsharks to be compatible with the 5.8 500mw transmitter?
Is that a lawmate tx? If so, it's not compatible with the rx in the fatsharks, but you can still hook the goggles up to the vrx using the cable that comes with the goggles.
If you want a compatible vtx, you need either an ImmersionRC 600mW 5.8 vtx, or a fatshark branded one (I think they do a 100mW and a 10mW). HK has the 600mW one, but it's on backorder. ReadymadeRC had some in stock for the same price last I checked, as did BevRC, but they move through stock really quickly. Also, seeing you're in the US, RCG classifieds should have some good second hand gear for you
Thanks so much! If I decide to go with 1.3ghz for the video tx in the future, can I still use my fatsharks? I just heard that 1.3ghz at 300mw generally gives better distance than 5.8ghz at 500mw. Why is this? and where can I find 1.3ghz?
EDIT: would this UBEC work for the booster: http://www.hobbyking.com/hobbyking/s...BEC_3A_5v.html
it says 5 volt output. I would hook it up to a 1300mah 2 cell lipo.
ben maybe you want an other setup because 2.4 GHz rc with 1.2 GHz fpv is not going to work. Contact me on skype is easier
My youtube channel
There is no such thing as a dumb question. Only dumb people dont ask dumb questions, smart people ask dumb questions!
Bixler FPV
Annsman virus 2.0
are you available right now?
I don't have skype on this computer, but we can just pm I guess
