Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 88
    Administrator ftadmin's Avatar
    749
    FT Flyer - Scratch Build
    The FT Flyer is a scratch built air frame designed specifically for our 'swappable fuselage' series. The other wings in this series include the Nutball and Delta wing. This episode is a step by step build plan to show you how to make your own modified BluDart, The FT Flyer.
    Foam board swappable fuselage scratch build series is setup like this, the Nutball as a beginner, the FT Flyer as the next step up, then the Delta wing for advance flying.
    The FT Flyer (BluDart) is a great intermediate scratch build offering all the ease and fun as the Nutball but offering a nice transition into more aerobatics and aerial maneuvers helping you improve your skills and prepare you for the Delta wing.
    One of the best part of all of these wing designs is that they are constructed from inexpensive foam board, so if a wreck does happen, you're only out a dollar or two worth of foam.
    Scratch building these foam board planes is a fun way to learn more about RC flight, improving your flying and it's a cheap way to explore your creativity in designing your own airplanes as well as a great way to introduce friends into the RC hobby!
    The plans for the FT Flyer are available here:
    FT FLYER SWAPPABLE FINAL.pdf
    See how to build the swappable fuselage here:
    http://flitetest.com/articles/DeltaScratchBuild
Name:	ft flyer - flying2.jpg
Name:	ft flyer - foam board.jpg
Name:	ft flyer - parts.jpg
Name:	ft flyer - tail.jpg
Name:	ft flyer - built.jpg
Name:	ft flyer - servos.jpg
Name:	ft flyer - build2.jpg
Name:	ft flyer - build1.jpg
Name:	ft flyer - battery.jpg
Name:	ft flyer - 1.jpg
Name:	ft flyer - flying.jpg
Name:	ft flyer - nutball.jpg
Name:	ft flyer - ft flyer.jpg
Name:	ft flyer - delta.jpg
    Nice video! Quick question:
    I have the stock bixler engine (rated arround 1800kv) with an 30 amps esc. I would like to use a 6x4 or 5x5 prop with this for your swapable series. Will this work?
    No one can help me?
    My youtube channel
    There is no such thing as a dumb question. Only dumb people dont ask dumb questions, smart people ask dumb questions!
    Bixler FPV
    Annsman virus 2.0
    Anyone?
    My youtube channel
    Bixler FPV
    Annsman virus 2.0
    Rotor Riot! colorex's Avatar
    5,663
    Quote Originally Posted by Nonamerc View Post
    Anyone?
    Thught you would know... It's a bit on the heavy side, you could make a double scale Swappable series with that motor.
    RR5 Alien 5" - KISS FC · KISS 24A ESC · Lumenier 2206 2350kv · HQ 5x4x3 · HS1177 · Unify Pro · X4R-SB · Lumenier 1300mAh 4S 60C · Thunder Power Adrenaline 1300mAh 4S 80C
    Quote Originally Posted by colorex View Post
    Challenge accepted
    (JK first I will need to finish my wing)
    My youtube channel
    Bixler FPV
    Annsman virus 2.0
    8
    Resposting (with some edits) from Comments section:
    I built this over the last couple of weeks and my order of electronics from Hobby King arrived on Tuesday.
    There appear to be some errors in the build video regarding measurements. I tried building the undercarriage out of .7 mm wire (14:25 in Delta build video) but it just flops all over the place.
    Would you recheck the wire diameter please? It has to be bigger than .7 mm!
    Also you show the wheel axles being bent with the voice over saying "an inch and a half" but if you watch carefully (14:36 in Delta build) it is actually .75" I got quite confused here and bent it at 1.5" which looked really odd. Its like the voice over was scripted with out reference to what was going on in the video.
    You have in the plans "C.G. IS 20-30% BACK ON CENTER OF WING". Are you able to clarify if this is measured from the front to the back centre of the wing section. My wing is 40cm at the centre line, front to back. So is C.G. then between 8cm and 12cm from the front of the wing front apex?
    Still waiting for wind and rain to go away so I can try maidening this. Once I've mastered the basics with this I'll swap in the Delta I've also built. Bring on the fine, almost windless days.
    5,663
    Quote Originally Posted by Hal9000 View Post
    Here is where you need to be a "DIY" guy. Use whatever works!
    And Flite Test isn't scripted, that's why they make this kind of mistakes!
    8
    I am a firm believer in the "do it once, do it right" and "measure twice, cut once" school of thought. Peeves me having to redo something, especially when I am following instructions of experts...
    But on the other hand this experience is character building, so I might just add hand launching and catching to my expanding range of RC skills.
    7
    I hade similar problem when built my FT-flyer. But it is only a help, make a double landing gear instead. But it is diy so you have to rethink and adjust some specs. After all it is free.
    I have not flown my FT-flyer but I think you whant the CG 8-12cm from the front of the wing front edge. That is information from RC-groups forum.
    I will try to use the swappable fuselage to build a trainer with ailerons but I am missing the servo´s for that now. But that is a separate forum post for that build.
    8
    Well I think I worked out what size wire Scott was meant to say for the undercarriage.
    .07 inch (not .7 mm) seems to be rigid enough, and seems to match what he's using in the video.
