Results 1 to 10 of 14
Thread: Mini Quadcopter (ala David Windestal, RC Explorer) build thread by glydr
    How many letters do we ge glydr's Avatar
    Canberra, Australia
    741
    3
    Currently on the workbench of glydr is a mini quad much in the fashion of that of Sensei Windestal, who I blame for my multi-rotor addiction. Thank you David (if you are reading this) in the positive sense :thumbsup:
    The HK Super Mini Quad thread has had quite some views (over 10,000!) so I thought some may appreciate my take on the mini quad.
    Shopping list is pretty much per David's, and includes;
    5g Hextronic Motors (4 of): http://www.hobbyking.com/hobbyking/s...6312&aff=61689
    Plush 6A ESCs (4 of): http://www.hobbyking.com/hobbyking/s...4318&aff=61689
    5x3 MR prop packs: http://www.hobbyking.com/hobbyking/s...ting_6pc_.html
    6x6 CF tube square (1 is enough for 1 quad): http://www.hobbyking.com/hobbyking/s...ting_6pc_.html
    And, of course, a multirotor board of your choice: http://www.hobbyking.com/hobbyking/s...ega168PA_.html
    Coated wire I had to hand, as well as heat shrink and the like.
    The CF tube was cut to length with a dremel. One length at 340mm, and two at 167.5mm. Thus arranged in a cross will place the chosen motors 160mm from the centre.
    To help keep everything straight I drew the cross on a piece of paper, which was placed under a plate of glass which served as a flat surface for gluing everything together with epoxy. A small scrap of paper between the joint and the glass prevents the frame sticking to the glass.
    Two sheets of thin-ply were cut (the same shape as a KK board) to serve as a base for the ESCs and a plate to velcro the battery to. They also stiffen the frame. These were PVAd together before epoxying to the frame.
    The coated wire was de-coated at the ends with a knife, before preparing the ends with solder. Like David I drilled holes near the centre to thread these wires through.
    The motors will be zip-tied in place as this one has been.
    The boom lengths indicated above make for 160mm from motor shaft to centre when the motor mounts are zip tied such that the 'x' reaches the end of the boom, as photographed.
    That's it for now.... waiting on some mystery items from HK which should help orientation.
    Is that order here yet lobstermash?
    Senior Member SteveOBHave's Avatar
    Sydney, Australia
    289
    Nice work! I'll keep an eye on this
    Epoxi Flyer KKArioKA's Avatar
    Jan 2012
    Rio de Janeiro - Brasil
    681
    NIIICE, another glydr build log !!
    subscribed ! :P
    YAY! Let's see how it goes. Why not KK 2.0?
    Senior Member IamNabil's Avatar
    Burlington, VT
    233
    2
    Pretty!
    S107G, Doublehorse 9116, mCP x, mQx with nifty orange blades, Parkzone P-51 Micro, an eHawk 1500, a Flyzone Calypso, a Crashtesthobby Titan, a ST Blaze, and my tank, an AXN Floater Jet.
    Canberra, Australia
    741
    3
    Cheers all.
    Quote Originally Posted by colorex View Post
    I actually bought all these bits some time ago, before the LCD KK board was released. I do have one of those boards however it is currently stuck to my tricopter.
    Propaganda machine
    Canberra, Australia
    1,807
    Quote Originally Posted by glydr View Post
    At this rate it'll arrive before my FrSky stuff
    Nice build. What are you going to do with this quad?
    Canberra, Australia
    741
    3
    Quote Originally Posted by lobstermash View Post
    Umm, fly it.
    Jan 2012
    681
    where is it ?
    Hey nice! After you finish it, please post a video here, we are waiting
