Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    Elemental Madness Carbon's Avatar
    Apr 2012
    Battle Ground, WA
    746
    FrSky DJT module wont fit in 9x!
    So I just received my Turnigy 9x from Hobbyking along with the Frsky DJT module seen here:http://www.hobbyking.com/hobbyking/s...8FR_II_RX.html
    But it wont seat in the transmitter!?! What is up with that? Has anyone else had this problem?
    "Trust me, it's suppose to fly that way..."
    Propaganda machine
    Canberra, Australia
    1,845
    Mine just popped straight in...
    Never argue with an idiot... They'll take you down to their level and beat you with experience
    Apr 2012
    Battle Ground, WA
    746
    hmmm...I guess I will have to send it back. Dang it!!
    Propaganda machine
    Canberra, Australia
    1,845
    Check what the issue is? Are the pins not right? Or is it a fit issue?
    Apr 2012
    Battle Ground, WA
    746
    fit issue. The corner where the pins are wont seat, like it is just blocked by something.
    Propaganda machine
    Canberra, Australia
    1,845
    Sounds like it's blocked by either the pins or the bit of plastic at the base of the pins... I've heard of some people having fit issues, but it's been fixable by slightly enlarging the square bit around where the pins go into the module. Can you post a pic of you tx without the module, and the back of the module?
    Apr 2012
    Battle Ground, WA
    746
    sure, give me a sec
    Apr 2012
    Battle Ground, WA
    746
    there you go^
    I think it is the bit of plastic around the pins. Stupid design....
    Propaganda machine
    Canberra, Australia
    1,845
    The idea of the plastic is to isolate the connections and make a snug fit with the module... Are you able to wiggle the module side to side as you push it in?
    It does look like your plastic bits stick out a little further than mine, by maybe 1mm or so, but it's hard to tell from just the photo.
    Apr 2012
    Battle Ground, WA
    746
    no wiggle at all, it is snug there.
