Results 1 to 9 of 9
    Pretoria , South Africa
    38
    Red Brick ESC for Quad X
    Hi guys
    finished my Quad X build this weekend, and used the build video below to pick some of my parts
    http://flitetest.com/articles/H_Quad_Scratch_Build
    It mentioned in the build that the Red Brick ESC's would keep up, but I have found that they fail.
    The problem seesm to be with the PWM rating of 400hz of the i86 KK board for the ESC's, they can handle the update signals sent at such a high frequency.
    I woul need to replace all my ESC's with PLUSH ESC's but beofre I do that, I just want to know if anyone else experienced the same problem.
    Symptoms : The I will start up my Quad, hover for a couple of seconds, and one of the motors would just die. Test the ESC on a seperate setup, it works, but as soon as I reconnect it to my KK board, it fails, and this is repeated for the other 4 ESC's as well.
    Thanks
    Arno
    You could reflash them, if you have the time and skill...
    http://polakiumengineering.org/?p=1112
    RR5 Alien 5" - KISS FC KISS 24A ESC Lumenier 2206 2350kv HQ 5x4x3 HS1177 Unify Pro X4R-SB Lumenier 1300mAh 4S 60C Thunder Power Adrenaline 1300mAh 4S 80C
    38
    Thanks I saw this article, but time I do not have, skill maybe
    Quote Originally Posted by Arno1978 View Post
    The comment on the article says that some arrive flashable, others don't... Seems to be a dodgy issue... But I don't understand why they would fail... Have you tried changing the timing?
    38
    According to what I know and seen is that these 20A Red Brick ESCs are very basic in programming them, and they cannot be programmed for a different timing setting, unless I have missed something.
    I have 4 Turnigy Plush ESC's that I will try out, they will work, the only catch is one of them is a 25A ESC the rest is 30A, but I have seen articles where they mention that as long as the ESC calibration is done correctly then it shouldn't cause a problem.
    Kailua, Hawaii
    105
    you could always just get some of these...
    I have the RedBricks for my Ycopter. I find that they do an ok job with the gyros dialed down, but of course that makes it pretty hard to control, constant corrections are necessary.
    My ESCs don't have the programming pads, so I was going to make a flashing tool with polymer clay to flash the chip directly, but opted to get some micro probe clamps (https://www.sparkfun.com/products/10086) to do the job instead.
    I am planning to do a write up of my process. I am hoping it works, otherwise I'll be getting some new ESCs. I'll report on my success/failure, they are ATmega chips so I don't see why it wouldn't work.
    Hi guys
    Thanks
    Arno
    I just finished the exact same build, and had the exact same problem. H-quad, with redbrick esc's and the kk2 board. could not figure out what the problem, and ironically enough i also just decided to purchase plush escs. ive been looking for someone on the web with the same problem i was experiencing. glad to know im not alone. but upset with the performance of those esc's..
    I have watched my H quad go down twice as a result of the Red Brick ESCs - they live up to their name! I will be replacing my Red Bricks with something more reliable, not sure yet but I'm a bit ticked on the reliability of those.
