Results 1 to 4 of 4
    808 #18 Keychain camera for FPV
    The 808 #18 camera has an AV out on it, thus making possible to use it as the camera for FPV. However, I have also heard that there is some lag in the AV out. I was wondering if anyone has tried it and what they think? Currently I am using the 200mW 900mHz system from hobbyking. The camera that it comes with is terrible in almost every way possible, so even if the #18 is so-so, it would still be an improvement from what I have.
    Thanks,
    Ross
    Junior Member Flying's Avatar
    New Zealand Auckland
    29
    I have the 808 #16 camera and have tested the video out on it. It outputs NTSC and for some reason was letter-boxed on my screen that I use for fpv. I would not recommend that you use the camera for FPV as it does not handle light and dark well. There was not a much of a notable lag on the number 16 camera that I have when displaying video out.
    Get this camera if you can it's amazing: http://www.securitycamera2000.com/pr...-Menu-DNR.html
    Don't let wind stop you flying
    Amateur Extra Class K5TWM
    3,103
    This camera is reported to be VERY good for FPV:
    All people either serve the devil or God.
    To serve God you must follow his instructions
    because no man can think as God does.
    To serve the devil takes no effort or instruction
    ...just do anything you like.
    Who do you SERVE?
    Thanks, I won't bother with the 808 #18 then. I'll probably have to pick up one of those cameras because I mostly fly at dusk so I need a camera that can handle a bright sky and a dark ground at the same time.
