Results 1 to 10 of 20
    airc-pirates.com AircPirateNinsei's Avatar
    Apr 2015
    Koethen, Germany
    267
    AP Rascal Racer (1000 mm | 39.37 in)
    Here is the larger version of the Rascal Racer with a wingspan of 1000 mm or 39.37 in.
    Scaling up the parts was easy but adjusting them back to the thickness of DTFB took some time.
    The result is a BETA plan. I still have to test the thrust angle, that is the reason for the BETA-plan.
    The prototype is ready for the maiden flight.
    This version has a rudder.
    Specs
    Wingspan: 1.000 mm | 39.37 in
    Center of Gravity (CG): 37 mm | 1.46 in
    Length: 690 mm | 27.17 in
    Weight (without Battery): 452 g | 15.95 oz
    Weight (with Battery): 690 g | 24.34 oz (4S 2200 mAh)
    Expo: 30 %
    Channels: 4 (Throttle | Ailerons | Elevator | Rudder)
    The weight of the brushless motor is only 70 g, so the rudder and elevator servos must be placed near to the front.
    Electronics – Test Setup
    Motor: 2836-1100kv
    Propeller: 74.5
    ESC: 40 A 4S
    Servos: 4 x 9 g (HXT900 or TGY-1800A)
    Battery: 2200 mAh 4S
    Build Plan – BETA Version
    DOWNLOAD FREE PLAN
    If you want a smaller version, look here: AP Rascal Racer (700 mm | 27.56 in)
    Airc Pirates - the sky is our ocean
    Free Build Plans
    | Current Projects | CARD GAME: Foam Board Planes
    planebreaker2000's Avatar
    Jun 2015
    El Paso Tx
    298
    looks good hopefully the maiden goes fine. I will build this as soon as I get a chance.
    1. build, 2. fly, 3. repeat.
    Apr 2015
    Koethen, Germany
    267
    Thank you! I hope so too!
    Free Build Plans
    Jun 2015
    El Paso Tx
    298
    Plans printed and the build can start soon. I really like the looks of this plane, and the plans look great. Thanks again for the upsized plans. I know that doing that is a lot of work.
    Apr 2015
    Koethen, Germany
    267
    The maiden flight was successful, but the rudder had no effect! It is too slim.
    I enlarged the rudder area and updated the BETA Plan (PART 13 - VERTICAL STABILIZER).
    Please use this updated part!
    The Rascal flies with the electronic test setup super straight - the thrust angle is right!
    The motor power is sufficient, but it's not a Racer with this motor. You can fly comfortably at half throttle.
    With the larger rudder it makes a huge curve.
    Free Build Plans
    Apr 2015
    Koethen, Germany
    267
    There is lot of space in the fuselage. I think i'm going to build a 1000B and reduce the width of the fuselage to 55mm and the height to 50mm without cover. The width of the nose will be only 45mm, perfect for a 45mm spinner. However, the brushless motor would not be interchangeable!
    Free Build Plans
    Jun 2015
    El Paso Tx
    298
    That sounds like the way I like to build my planes. Sleek and streamlined
    viggen's Avatar
    Feb 2015
    uk
    150
    I really want to build this plane.but my local print shop says its to big to print,they have printed the ft,racer,spitfire,explorer with no problems.can you make a tiled versions,or change the lay out?
    Thanks
    Apr 2015
    Koethen, Germany
    267
    Quote Originally Posted by viggen View Post
    Thanks
    No problem, i added different formats. Look here: http://airc-pirates.com/en_US/ap-rascal-racer-1000/
    And i updated the BETA Plan (PART 25 - THROW GAUGE).
    If someone needs a different format, please contact me!
    Free Build Plans
    viggen's Avatar
    Feb 2015
    uk
    150
    Thanks i will see if the 600x500 works
