Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: I think RMRC sent me the wrong RX!!!!!
    Ontario, Canada
    57
    Exclamation I think RMRC sent me the wrong RX!!!!!
    So about a week ago I bought my first fpv gear from Readymaderc. In my order was a 1.3ghz TX and RX. When my order arrived I opened the box and took everything out to look at it, everything looked right to me. a couple days later I go to run everything for the first time, and I am having trouble getting video. I start looking at my RX and I see stickers saying "900 SF" and "0.9GHZ". So I am lead to believe that they sent me a 900mhz RX instead of a 1.3ghz RX.
    Am I mistaken, or did they make a mistake?
    Maxwell
    1,006
    Is it single or multi channel. I have seen 900MHz that had channel capacity up to 1.3GHz selectable via dip switch.
    "We shall pass this way on Earth but once, if there is any kindness we can show, or good act we can do,
    let us do it now, for we will never pass this way again."
    Propaganda machine
    Canberra, Australia
    1,809
    I think that system is the updated version of the one Hobbyking sells - the receiver is able to work with both the 1.3Ghz and 900Mhz transmitters (so long as you select the right channel on the rx).
    Never argue with an idiot... They'll take you down to their level and beat you with experience
    Ontario, Canada
    57
    This is the TX and RX that I ordered:
    TX: http://www.readymaderc.com/store/ind...oducts_id=1017
    RX: http://www.readymaderc.com/store/ind...cac1942063db69
    I tried both frequencies that I can pick from with the TX, but I had nothing on video. I did get a vary fuzzy image when I held the TX really close to the RX, but not good enough to fly with.
    Propaganda machine
    Canberra, Australia
    1,809
    Can you change the channels on the rx? The one you linked should have 4 channels, two of which correspond to the tx. If you can't change the channels on the rx they've definitely sent you the wrong one.
    Ontario, Canada
    57
    I can change the channels on the RX, I have tried channels 1 and 2 on the RX because those are the only available channels on my TX.
    Propaganda machine
    Canberra, Australia
    1,809
    It sounds like they've sent you the wrong one. Channel 1 and 2 on the rx should correspond with those on the tx. Time to test out their customer service...
    Ontario, Canada
    57
    Ok, Thanks for all the help!
    Yes they send you the wrong one! I have both the same transmitter and receiver from readymaderc and it does not has stickers with 0.9 GHz. Contact readymaderc I am 100% sure that they will help you out!
    Are you going to use an UHF system with your 1.2 GHz fpv?
    My youtube channel
    There is no such thing as a dumb question. Only dumb people dont ask dumb questions, smart people ask dumb questions!
    Bixler FPV
    Annsman virus 2.0
    Ontario, Canada
    57
    Ok, I thought it was odd how there was stickers saying "900 SF" and "0.9GHZ" on a 1.3GHz RX.
    For now I'm planning on staying close to me (under 500m) and using my Spektrum 2.4GHz gear. I do plan on getting that EZuhf you suggested to me on the other from. I like how it just plugs into the trainer port on the RC TX, it seems like with all the other ones you need to do some mods to your RC TX for it to work.
