Results 1 to 10 of 14
    airc-pirates.com AircPirateNinsei's Avatar
    Apr 2015
    Koethen, Germany
    290
    FF2017 Int. Racers: Messerschmitt Me 209/Bf 109R
    This is my project:
    It is a Messerschmitt Me 209 (V1).
    Designer: Willy Messerschmitt
    First flight: 1 August 1938
    Number built: 4
    Full scale wingspan: 7.8 m (25 ft 7 in)
    1/6 scale wingspan: 1.3 m (51.18“)
    From Wikipedia, the free encyclopedia:
    The first Messerschmitt Me 209 was a single-engine racing aircraft which was designed for and succeeded at breaking speed records. This Me 209 was a completely new aircraft whose designation was used by Messerschmitt as a propaganda tool. Although the aircraft was designed only to break speed records, it was hoped that its name would associate it with the Bf 109 already in combat service. The designation Me 209 was given for propaganda purposes to cause confusion with the Messerschmitt Bf 109, the Luftwaffe's primary fighter throughout World War II. It was later reused for the actual proposed successor to the Bf 109.
    Read the full article.
    Revere's Avatar
    Jun 2015
    Sakura, Japan
    209
    I like all these old racers popping up lately, the bugatti and now this, next we need a Caudron c450 or c460, get some pylon races going on. It's good to see some pretty planes that aren't warbirds.
    I have a feeling though that you'll need to increase elevator area, or use the entire surface to have adequate authority. The elevator control surfaces on the plans look a little too little, especially if you run a beefy setup.
    I don't crash, I'm simply an expert at landing components individually.
    High Alpha! localfiend's Avatar
    Mar 2015
    Eastern WA
    1,380
    Quote Originally Posted by Revere View Post
    Heh. Check out this thread:
    http://forum.flitetest.com/showthrea...onal-Air-Races
    There's a reason for all the racers.
    I happen to have a magazine somewhere that has some scale documentation on that plane. Message me if you want me to start digging.
    Reinventing the wheel, one corner at a time.
    Skill Collector rockyboy's Avatar
    May 2015
    Alexandria, VA USA
    3,681
    Great to see another blue plane in the race! (I'm working on the Caudron C.460 which was only painted that deep blue too)
    The Me209 seems to be very stubby compared to many of the racers of the 30's. Wonder how that will effect the control surface size needs and handling... so many exciting things to learn and try!
    Also, I hope you don't mind but I'm going to try and steal your excellent top hatch design from the Rascal Racer for my Caudron. I love how easy it is to access all the equipment on that design.
    Thanks!
    I want YOU to join us in the 2018 Flite Test Forum WWII Design/Build Challenge!
    My hanger listing, build threads, conversion projects, and Taranis radio mods are Over Here....
    HilldaFlyer's Avatar
    Jan 2014
    Worcester, MA
    818
    Quote Originally Posted by rockyboy View Post
    May I ask about the excellent top hatch design? I'm looking to do one and need some ideas.
    - David -
    Love the Fiberglass Skinned Foam Core.
    Learn, Build, Fly, Crash, Repeat
    fb: David Hill, YouTube: Hillda Flyer
    May 2015
    Alexandria, VA USA
    3,681
    Quote Originally Posted by HilldaFlyer View Post
    Ninsei has some great pictures on his Rascal Racer article that show the hatch opened up
    http://flitetest.com/articles/ap-ras...00-mm-27-56-in
    Basically the entire top of the plane is held on with three simple plywood hooks. Forward motion keeps it held in place in flight, and it's simple to slide it all forward and off to get inside. Also, on a stiff nose-in landing, it's very impressive to have the entire top of the plane bounce off separately!
    Apr 2015
    Koethen, Germany
    290
    Thank you for the hint! I will see how it works.
    Quote Originally Posted by Corbarrad View Post
    That would be fantastic! The message is sent! Thank you!
    Also, I hope you don't mind but I'm going to try and steal your excellent top hatch design from the Rascal Racer for my Caudron. I love how easy it is to access all the equipment on that design. ...
    I don't mind. Thank you! I would like to see other designs with this HatchHookLock.
    Are you satisfied with your Rascal? Do you have any suggestions for it?
    May 2015
    Alexandria, VA USA
    3,681
    Quote Originally Posted by AircPirateNinsei View Post
    I like the Rascal - especially the construction techniques - but I don't like the swap meet motor I put into it. And of course I glued in the firewall and it will be a huge pain to switch motors, but I'm probably going to do that. The motor problem I'm having is the ^#&^ built in prop saver has an angled face against the props instead of a perfectly flat face. And I keep having the props start wiggling and fly off every time I try to power it up with a 3s battery.
    The props stay on just fine with a 2s, but that just doesn't give me enough speed - she is always at the edge of stalling even at max throttle. Should have went with a bigger motor that had a standard prop mount and spinner, but I went with something cheap and on hand instead. Oops!
    Apr 2015
    Koethen, Germany
    290
    Yesterday the ordered magazine arrived. It contains the recordplane Messerschmitt Me 209 with highly detailed scale drawings, an explanation of types and history, background and historical photographs - a must have for my project! Thanks again to Corbarrad for the hint!
    Now i can start!
