Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
Thread: AP Godai (STOL)
    airc-pirates.com AircPirateNinsei's Avatar
    Apr 2015
    Koethen, Germany
    267
    AP Godai (STOL) - 1000mm (39.37 in)
    Here is a video of the single engine version with the STOL wing and wheels:
    FEATURES:
    • FAST AND EASY BUILD – NO POSTERBOARD REQUIRED
    • SINGLE OR TWIN ENGINE LAYOUT
    • USE COUNTER ROTATING PROPELLERS FOR NO UNWANTED TORQUE EFFECTS IN THE TWIN ENGINE LAYOUT
    • THREE TYPES OF WINGS - ROOKIE, TRAINER OR STOL
    • USE RUBBER BANDS TO MOUNT THE WING FOR EASE OF TRANSPORTATION
    • REMOVABLE NOSE IN THE TWIN SETUP (USABLE FOR FPV CAMERA)
    • MAIN UNDERCARRIAGE WITH HUGE WHEELS
    • OPTIONAL SKIS AND FLOATS
    • EASY ACCESS TO ELECTRONICS AND BATTERY
    SPECS:
    • WINGSPAN: 1.000 mm |39.37 in
    • CG: 50 mm | 1.97 in
    • LENGTH: 815 mm | 32.90 in
    • DRY WEIGHT: 265 g | 9.35 oz WITH STOL WING
    • ALL UP WEIGHT: 708 g |24.97 oz WITH STOL WING AND 2200 mAh 3S BATTERY
    • AUW WITH WHEELS: 741 g |16.13 oz
    • AUW WITH SKIS: 748 g | 26.38 oz
    • AUW WITH FLOATS: 856 g | 30.19 oz
    • EXPO: 35 %
    • CHANNELS: 3 - 5 (THR | ELV | RUD | AIL | FLP)
    ELECTRONICS - SINGLE ENGINE LAYOUT:
    • MOTOR: 1100kv (2836) WORKS WIT FT POWER PACK C
    • PROPELLER: 9x5
    • ESC: 30A
    • SERVOS: max. 6 x 9g
    • BATTERY: 2200mAh 3S
    ELECTRONICS - TWIN ENGINE LAYOUT:
    • MOTOR: 2x 2300kv (2204) WORKS WIT FT POWER PACK F
    • PROPELLER: 2x 6x4 (CW & CCW)
    • ESC: 2 x 20A
    BUILD PLAN
    DOWNLOAD FREE DIY PLAN
    Old first post:
    Easy to build and easy to fly - that will be the AP Godai!
    It works with FT Power Pack C and adapts to any surface, whether it is ground, snow or water.
    The floats are still in work - thanks to localfiend for the basics!
    The flaps allow a short takeoff and landing (STOL) or just cruising in the sky.
    Here are some photos of the prototype with wheels and FPV or Ski and Micro FPV.
    Airc Pirates - the sky is our ocean
    Free Build Plans
    | Current Projects | CARD GAME: Foam Board Planes
    Apr 2015
    Koethen, Germany
    267
    Who likes belly landings, can simply omit the landing gear!
    Free Build Plans
    Apr 2015
    Koethen, Germany
    267
    The winglets are perfect for integrating LED boards!
    Free Build Plans
    Jul 2014
    Yuma, AZ
    593
    Very Interesting. Cheers!!!
    Apr 2015
    Koethen, Germany
    267
    The floats (Setup 3 of 3) are ready!
    Three setups for (almost) every subsoil: earth (wheels), snow (ski) and water (floats)!
    Now I need a lake to test the floats and snow for the ski.
    Free Build Plans
    Apr 2015
    Koethen, Germany
    267
    What would you prefer: a closed wing with winglets or a standard wing?
    Free Build Plans
    planebreaker2000's Avatar
    Jun 2015
    El Paso Tx
    298
    Closed wing with winglets definitely. Cool plane design!
    1. build, 2. fly, 3. repeat.
    Skill Collector rockyboy's Avatar
    May 2015
    Alexandria, VA USA
    3,402
    Winglets definitely - adds a cool touch, and perhaps better yaw stability too.
    I want YOU to join us in the 2018 Flite Test Forum WWII Design/Build Challenge!
    My hanger listing, build threads, conversion projects, and Taranis radio mods are Over Here....
    Jack thatfpvkid's Avatar
    Nov 2015
    Pennsylvania
    20
    Looks great! Will you release plans?
    Apr 2015
    Koethen, Germany
    267
    Thank you so much!
    The plan is almost finished (with the closed wing and winglets - thanks to planebreaker2000 and rockyboy for the feedback and localfiend for the float guidance). It will be soon available for free! Since i have made a few changes in the build plan, i have to test them and build a new Godai. And then i want to create a sticker set or paper replacement kit and a flightvideo. So there is still a lot to do and it takes some time until the build plan will be published.
    Free Build Plans
