Page 17 of 17 FirstFirst ... 7 15 16 17
Results 161 to 169 of 169
  1. #161
    CheapSunglasses's Avatar
    Join Date
    Mar 2017
    Location
    Katy, Texas
    Posts
    37
    Quote Originally Posted by rockyboy View Post
    She looks beautiful!! Congrats!!
    Yeah, Solite takes some practice for sure - it's all I've been using since I got back into the hobby a couple years ago (some previous experience with Monokote in the late 80's). There are lots of tips and pictures of how to use it out there, but a lot fewer videos - and it really takes a video or in-person instruction to get past a lot of the headaches I think. Maybe I should talk Joker into filming one
    A video would be great! I just got a Mountain Models Dandy delivered that I plan on building this winter. It will be my first balsa build. I'm sure that I will need help with the covering.
  2. #162
    Turbojoe's Avatar
    Join Date
    Nov 2014
    Location
    Mesa, Arizona
    Posts
    389
    Your EVA looks great. The black and blue really look good together.
    Joe
    The nonsensical ravings of a lunatic mind.....
  3. #163
    Successful maiden!!
    Zero wind. Tried a taxi test and it just took off at less than 1/2 throttle. Tried to set it back down but it just floated along pretty straight so I hit the gas instead of risking a nose over in the grass. Two clicks right rudder. Two down elevator. Chickened out when I lost orientation briefly in the dusk. Landed like a feather right on the running path.
    May need more power than 150 watts to fully satisfy ;-) It does float right along at about 1/3 throttle.
  4. #164
    Turbojoe's Avatar
    Join Date
    Nov 2014
    Location
    Mesa, Arizona
    Posts
    389
    Quote Originally Posted by Try-n-glide View Post
    Congrats on the maiden!
    Be VERY careful adding TOO much power. The ailerons will flutter at high speeds on the stock Sport wing. I always have to cut power on down lines or I can hear and see them buzzing like crazy on both EVA Sports. I mounted the aileron servos mid wing on the twin conversion but haven't flown it to see if that helped.
    Joe
  5. #165
    Have any of you tried to harrier the EVA? I am trying to get into a parachute/elevator maneuver that seems to be the one you transition into a harrier from. Haven't quite got it worked out. Seems like it either wants to glide or stall and porpoise. If I power up from there it just pulls forward instead of pulling up into a stalled harrier type position.
    If you have gotten it to harrier what power level? I'm running a Sunnysky 910kv at 160 watts, and I don't know that it will be enough.
  6. #166
    Aviation Enthusiast nhk750's Avatar
    Join Date
    Sep 2016
    Location
    Seattle, WA
    Posts
    1,125
    The covering job looks great. Hopefully I can do that good when the time comes. Why tape hinges and not CA or nylon hinges?
    Too many airplanes and not enough time...
  7. #167
    A thousand pints of lite. Joker 53150's Avatar
    Join Date
    Aug 2012
    Location
    Muskego, WI
    Posts
    3,001
    Quote Originally Posted by nhk750 View Post
    One thing that isn't super obvious in the pictures is that the hinged surfaces are very thin. It would be difficult to split the balsa and insert a hinge (even a CA hinge) without doing further damage to the structure. The taped hinges are a great compromise - they don't look as nice, but they work great and don't damage the wood.
    One of the planes my dad got a while back was an EVA, and the builder tried using regular hinges. He ended up tearing up the internal structure in an attempt at getting the hinge in place, resulting in very weak construction. I maiden his planes, and wouldn't touch that one until he fixed the problems. It was repaired and the tape hinges were used.
    Joker
    Balsa dust is a wonderful thing, make some today!
  8. #168
    Skill Collector rockyboy's Avatar
    Join Date
    May 2015
    Location
    Alexandria, VA USA
    Posts
    3,440
    Flight Report: Haven't attempted a harrier yet, but ran about 6 batteries through her this weekend in very calm air and loved every minute!
    Well, except for the minute when canopy came off the very first time I went vertical, but another club member saw where it came down and we found it easily. I was very happy with how stable she was to land without the canopy on, and the rest of the day I just flew with the canopy taped in place. Will build a latch or just put in a bigger magnet before I take her out again.
    And instead of feeling like I have to fly a basic pattern and play defense from the wind and trees like I often do, I spent most of the time practicing getting straight loops and working on hammer head turns. Really feeling like I'm starting to move from a basic to an (early stage) intermediate pilot now.
    I want YOU to join us in the 2018 Flite Test Forum WWII Design/Build Challenge!
    My hanger listing, build threads, conversion projects, and Taranis radio mods are Over Here....
  9. #169
    Turbojoe's Avatar
    Join Date
    Nov 2014
    Location
    Mesa, Arizona
    Posts
    389
    Bingo! She just keeps getting better.
    Joe
Posting Permissions
  • You may not post replies
  • You may not edit your posts
