Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    flyinggreek's Avatar
    Join Date
    Dec 2016
    Location
    Upland, Ca
    Posts
    75
    Choose your aircraft on your transmitter, scroll down to "Setup List" and go to the setup menu. Scroll down to "Monitor" and you will see all the graph of all the throws. Without the aircraft plugged in, operate all the axis and you will see the monitors move. Typically the Throttle will start at about 1/4 throw and end about 3/4 throw but it should be linear. I have done this and found bad settings on my program before.
  2. #12
    Settings
    The monitor has the throttle at 1/4 at lowest and 3/4 at highest.
  3. #13
    Join Date
    Dec 2016
    Location
    Upland, Ca
    Posts
    75
    Ok, thats normal. Sounds like you need to set the ESC. Check the website for the proper procedure to reset the Speed controller that I posted. Like I said, I would hate to tell you the wrong procedure.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
