Results 1 to 3 of 3
Thread: FC problems
  1. #1
    FC problems
    Hello and good evening, I am stumped about my FC. I have a Seriously Pro F3 Mini and for some reason since my last rebuild I haven't been able to have my radio control anything. I re soldered everything to the board to "neaten" up my quad and now the radio won't even notice when the power is on or off in the quad. I have never had this problem and I'm hoping I may need to re flash my firmware or something? I am not good with the cleanflight program but I am getting slowly better and I would like to continue using it. Does anyone have any ideas? Thank you for your time
  2. #2
    Kite Eating Tree Trimmer cranialrectosis's Avatar
    Join Date
    Jul 2013
    Location
    Colorado Springs
    Posts
    4,509
    Please post a well lit, detailed photo of the connection between your flight controller and the receiver.
    Freiheit schöner götterfunken tochter aus elysium!
  3. #3
    TWO DOLLARS!
    Join Date
    Jul 2016
    Location
    Everett, WA
    Posts
    114
    Other than the picture, good troubleshooting says to work your way back to what worked & find out what went wrong in the middle.
    Do not change anything else. No flashing or whatever. This leads to a sort of panic where you fix unbroken things & potentially add other bad factors.
    Look hard at everything you changed from what worked, especially the soldering. By change, I mean rework also. If you touched it or something close, take a hard look at it. The continuity test on your multimeter will tell you more than your eyes can. It could be a damaged wire, cold solder joint, missing wire, wrong connection, etc, etc, etc.
    This is the main reason for the picture. It could be lots of things.
    megabotz
    Eleventy-first post!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
