Results 1 to 3 of 3
  1. #1
    Fly Angry PsyBorg's Avatar
    Join Date
    Jan 2016
    Location
    Upstate New York
    Posts
    2,572
    Make it go faster!! (Hotprops practice )
    This is my last Hotprops practice session. Still trying to find the fastest set up to fly in the sim. This one is my fastest so far.
    physics settings are:
    100 mm arm length
    200 mm body length
    50 mm body width at 535 gr
    5s battery spinning 5x5x3 inch props.
    RC rate is 2,2,2.05
    Super rate is .63,.63,.65
    Max vel is 1081, 1081, 1586
    and zero expo across the board.
    This is 60 degrees FOV with 53 degree tilt on the quad.
    I played with the motor kv slider until I found the highest thrust I could find which for this run was 1815 gr. Flat out run across the field above the obstacles got 172kph top speed. Originally I have been flying with the settings more close to the actual ones of my Alien in real life. I been doing a lot of sim flying with the bad weather so I figured its time to up the game and get some of the old reflexes back from my younger "I wanna race everything" days of speed.
    If anyone else uses this and has a faster settings feel free to post it here so other can try.
    "What ever the mind of man can conceive and believe..... he CAN achieve" Saying told to me by the teacher who inspired me to get into RC and rocketry back in high school. Long live Captain Cavill !!!
    "Go THAT WAY. REALLY fast. If something gets in your way.... Turn" quote from Charles de Mar a character in the movie "Better off Dead"
    Psyborg FPV You Tube channel.. https://www.youtube.com/channel/UC88...L6-KC9qTa2LgVA
  2. #2
    Troll Spammer LitterBug's Avatar
    Join Date
    Jan 2016
    Location
    Columbus, OH
    Posts
    679
    NICE PB!
    Cheers!
    Join Date
    Jan 2016
    Location
    Upstate New York
    Posts
    2,572
    I want to get even faster. I think in the straights I was topping out at either 163 or 168 kmh on that run but its hard to see with the camera not filtering it better. I REALLY need to get a screen capture for video that doesn't lag the games so I can record much better quality instead of using a video camera to film a TV. I will play around more now with prop sizes and weights an such to see what the fastest the sim can do is over time. Now I just need to build a quad that will fly as quickly and learn to pilot that at top speeds.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
