Results 1 to 3 of 3
  1. #1
    FT Tiny Trainer Center of Gravity
    This week I received my Tiny Trainer Get Started Package, and I just finished assembling it in the three channel configuration. After putting all of the electronics in, I found that the plane was very nose-heavy, so much so that I had to put the battery at the very back of the velcro strip to get it almost balanced. I'm looking for tips on ways to add a bit of weight to the tail so that I have room for finer adjustments up front. As it's my first plane I want to make sure I have it set up for the best learning experience
  2. #2
    Join Date
    Nov 2016
    Location
    EU, Czech Republic
    Posts
    28
    I'm using fishing sinker or nut.
    I had the same problem with my TT but I'm using different material here in Europe and bigger 1.050mAh battery. So I put ESC on the place of vecro and battery into the fuselage :-)
    http://imgur.com/a/uab6Q
  3. #3
    kdobson83's Avatar
    Join Date
    Sep 2015
    Location
    Louisville KY USA
    Posts
    211
    Hmm, I had no issue with mine. I use a 800mah 3s and have it pushed all the way up front, along with a voltage alarm right behind it. Balances perfect with no extra weight. But, as long as your build went good and you are checking CG at correct spot, about 1/3 of the way back on the wing, and it's still tail heavy, hotglue some weight on the tail. You can get some lead fishing weights, flatten out with a hammer (warning, this is fun) and glue on tail till you get CG close enough.
    If only...
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
