| Help | Store Account | FliteTest Dashboard
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Tactic ttx 850
  1. #11
    Rotor Riot! colorex's Avatar
    5,663
    Quote Originally Posted by Foam Addict View Post
    I also set up crow and other mixes variably on the remote, allowing me to have less of a shock!(relative noob here!)
    You're wondering why a variable mix is necessary when you already have variable channels, right? Well, say you want to set up spoilerons. You know, both ailerons go up to reduce lift. This needs to be a mix since the ailerons are already in the aileron channel. So if you set up that mix with the slider, then you can adjust the spoilerons as needed. On my DX6i I can only activate spoilerons (flaps set with different endpoints) with a switch - boom - all or nothing. With a slider controlling the mix you can slowly increase or decrease the effect.
    RR5 Alien 5" - KISS FC KISS 24A ESC Lumenier 2206 2350kv HQ 5x4x3 HS1177 Unify Pro X4R-SB Lumenier 1300mAh 4S 60C Thunder Power Adrenaline 1300mAh 4S 80C
  2. #12
    Fly the wings off Ak Flyer's Avatar
    Valdez Alaska
    1,594
    Well, you can leave the adjustment menu open and then as you're flying roll roller button to adjust the level you like. I would only do this to find a point I like and save it. I do see what you mean though. That would be something you would like to adjust on the fly. That makes sense. Another feature of the DX8 is the ability to slow servo movements for things like gear so they pop down or up slowly and scale like. I will have to see if it's possible to change the timing of a mix function.
    Good example. That's what I was looking for. Thanks.
    I haven't tried any gliders yet and with all my 3D planes and heli's as well as my scale planes I've never run across a situation where I wanted to dial it in. I have a dial on my DX8 that I can use but I never have. I actually try to program everything to my flight mode switch. I have all my rates, expo, governor and any mixing done programmed so that I can change it all with one switch and that keeps me focused on flying. Kind of like programming a run. A take off mode, middle mode, stunt mode, then back to middle and landing. Works for me anyhow. I like hearing how other people set up their stuff.
    "If at first you don't succeed, skydiving is not for you"
    My Fleet Photo Album http://forum.flitetest.com/album.php?albumid=33
    Spektrum DX8
    Align Trex600N
    Hobbyzone Super Cub LP (Brushless 480 and aileron mods, floats)
    Great Planes Cub .40, Sig Four Star .60
    AMA#970963
  3. #13
    Aug 2014
    Richmond, BC
    40
    does the TActic 850 bind to any tactic rx?
  4. #14
    Squirrel member Foam Addict's Avatar
    Nov 2012
    Denver Co.
    2,218
    Wow, I forgot about this thread. It will bind to any 2.4 ghz Tactic Rx, Tactic did manufacture some 27 an 72 mhz equipment, but aside from those, yes.
    I have a GAU-8. Therefore your argument is invalid.
  5. #15
    Aug 2014
    Richmond, BC
    40
    Cool
    Much thanks , I am seriously considering this radio as my turnigy 9x has only a model memory of 8. When I was just starting last year that seemed like a lot ...but 7. Planes later I have a upcoming problem ...lol
  6. #16
    Feb 2015
    Caro, Michigan
    17
    Quote Originally Posted by lordservant1 View Post
    I recently purchased this radio myself. I haven't had much time with it behind the sticks (weather sucks) but I find it to be quite nice. I am however coming from a handful of cheap RTF radios so this seems like a Cadillac to me.
